Question about Toshiba CZ36V51 36" TV
How do I replace the remote sensor on the front of my Toshiba CZ36V51...I have the sensor part....is this done by prying off the front black panel at the power button??
  • 1,557 Answers
You need to take the back off unplug all cables (mark were they go back) take of the fly back cable (top of tube) by lifting the rubber crimp the strike pins pull of. the take out circuit board and there at the front will be the ir sensor desolder it and replace with new one
good luck
let me know how you go
Posted on Dec 29, 2010
My toshiba 65in will not respond to my remote
The infrared sensor to your TV might be bad. It should be replaced. It is an easy to get part, and is cheap to buy from any electronic spare part shops. To access and replace it, you have to pull out the front panel PCB. In fact, you have to open the TV to replace it. The component will look somewhat like this.
9_25_2012_12_43_33_pm.jpg9_25_2012_12_43_54_pm.jpg9_25_2012_12_44_12_pm.jpg9_25_2012_12_44_46_pm.jpg
Sep 24, 2012 | Toshiba 32AF43 32" TV
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Feb 04, 2012 | RCA Televison & Video
Where is the remote sensor for the Toshiba 50A62?
Hello
Remote sensor is an internal component, and can be locakted just beneath the remote sensor window at the front panel of all TVs. It is usually a three terminal black colure component, diretly soldered to a circuit board. In some sets, it will be on a seperate circuit board, and in some otheres it will be soldered to the front panel control switches board. OK.
Mar 06, 2011 | Toshiba 50A62 50" Rear Projection...
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
After power button is turned on the led light flashes, and the only way I can get a picture is to bang on the front of the tv by the power button.
Sounds like you have a "Dry Joint" or bad connection, or even a faulty power switch.. this is a fairly common one... try a switch replacement first? Or look for a bad joint on or around the switch connections.
Jan 30, 2010 | Toshiba CZ36V51 36" TV
I have a Toshiba cz36v51 that won't come on...
I do not have that make and model. However:
Some remotes have to have a code set that matches the brand of the tv. Your remote should have come with a list of brands and codes.
Alternatively, the instructions for your remote should tell you how to determine which code to use.
Mar 20, 2009 | Toshiba CZ36V51 36" TV
Paper jam
The paper jams in the bottom because the leading edge hasn't reached the correct sensor in time, thus causing a jam message. Do a sensor test on the front panel of the printer before replacing any parts. Go into Diagnostics/Sensor test and you will see the letters across the top follwed by numbers below. Then you want to toggle the sensors located through out the paper path-usually black plastic hanging done into the tray areas. Up in output tray has black plastic hanging down-sensors. lift top cover and you can see the sensors on the left side of the top a black horseshoe shape is a sensor. This will help with the correct parts needed to be replaced.
Oct 02, 2008 | Toshiba TEC B-882 Thermal Label Printer
Toshiba 50A62 Remote Infrared Sensor
I have replaced these IR sensors before and it has solved the problem...they dont blow all the way..they just get weak......replace it.
Jan 25, 2008 | Televison & Video
Toshiba power led blinking
check your horonital output transistor could be defective.
Jan 26, 2007 | Toshiba CZ36V51 36" TV
Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Jun 12, 2006 | Toshiba CZ36V51 36" TV
Toshiba CZ36V51 36" TV Logo
174 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
