Question about LG DVD 6183 DVD Player
My lg dvd player model no.dv259-pm encountered a problem with cd tray not opening.. and cd is inside the tray..
SOURCE: LG DVD 6053 Disc tray does not open
This happens to my dvd player all the time. I know this sounds bad but I give it a few quick taps on the top of the player just after I press the open button and it opens for me. I have the same player as you also.
See how you go with it!!
Posted on Jul 08, 2008
Shuttle83
  • 1139 Answers
SOURCE: LG DVD RECEIVER LH T-9654
Hello shelby4844,
Is the front panel coming on? I ask because if it is not this is indicating possible power supply failure. In this case the switching power supply might be having a problem. I would suggest that you have someone who is skilled in electronics work on this problem for you since the power supply delivers current and voltage that could be hazardous to your health. Now that being said, this problem could be cause by a blown fuse, first unplug the DVD player, open it up, and find the fuse. The fuse will look like two metal caps separated by a glass or ceramic housing containing a strand of wire. Once you find this fuse. Take it out and measure it with an ohmmeter, the fuse should read 0 ohms (dead short from one cap to the other.  If the fuse is not bad then one of the other components may be bad, at this point, the testing should be done by someone who is skilled in electronics.
I hope this help,
Thank you,
Shuttle83
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: LG RH299H HDD/DVD does not read purchased DVD's
To unlock the region limitation of your machine:
(all the following is done on the remote)
Press <Home>
Go to the Easy Setup Menu
Go to <Setup>
"Hover" the cursor block over the Lock symbol (don't enter yet)
Enter 0000 on the remote
A Congratulations message comes up.
Press <Enter>
Posted on Jan 10, 2009
Stevenslav
  • 65 Answers
SOURCE: LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
Posted on May 21, 2009
  • 382 Answers
SOURCE: lg dvd player tray not opening and cd remains
possible cause is the lens of the dvd player is already been damage, try to use CD cleaner first if the problem still exist just sent it to a tech person to assist your problem on actual. Thanks
Posted on Sep 15, 2011
Unlock region on dvd player
please see the next steps: God bless you
  • 1 Turn on the DVD player.
  • 2 Open the DVD disc tray and keep it open. Power on your DVD player and open the disk tray. Leave the tray open as DVD region code hacks need the tray to be open as the code is entered for it to get activated.
  • 3 Press the "Home" key on the DVD remote.
  • 4 Select the "Setup" option.
  • 5 Select the "Lock" icon by using the arrow keys on the remote control.
  • 6 Press the number key "0," seven times on the remote. This is the code-"0000000."
  • 7 Confirm by selecting "OK" when you get the "Region Free" message. Insert an import DVD to test the DVD player.
  • 8 Repeat the steps again if the you encounter problems playing the DVD as you may have missed something.
Aug 01, 2012 | LG Televison & Video
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
The cd player on my kenwood ud302 is jammed shut with cd's inside...how do I open it .....any ideas please?
Barbara,
All CD and DVD players have a small hole in the front of the tray. This is for situation like you are in. Insert a paper pin into it and press a little when you encounter resistance. The tray will unlock and open.
Jan 11, 2011 | Sony CDP-C910 10-Disc CD Changer
My dvd will not open
All CD and DVD players have a small hole on the tray. If you insert a paper pin into this hole it will travel free some distance and then encounter resistance. Just press a little more and this will unhook the latch of the tray and the tray will open. You can even try the software method. From My Computer select the DVD drive and right click. One of the options is Eject. Click on it. The tray should open up.
Aug 25, 2010 | HP Pavilion dv6000z Notebook
On my LG RH387H dvd hard drive the dvd tray won't open fully and now it has started to open on power up and when i try to close it it keeps opening even though there is no dvd inside
mechanical timing and allignment is the prtoblem of your dvd player...you need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand..make sure that the cd loader reaches the limit switch before it closes..
May 18, 2010 | Televison & Video
How to unlock code for LG dvd player model DVX183?
Hi, have you tried this? It worked on my LG player.
1. Open DVD tray
2. Press "0000" on the remote.
3. A screen will appear saying NEW REGION CODE displaying the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD tray.
7. Power off
Feb 21, 2009 | LG XBR446 DVD Recorder/VCR
How to unlock region code for dvd player
1. Open DVD tray
7. Power off
Feb 15, 2009 | LG Televison & Video
Digital Apex dvd/cd/mp3 player tray won't open
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
Dec 16, 2007 | Televison & Video
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
LG DVD 6183 DVD Player Logo
102 people viewed this question
Computer Repairing
Computer Repairing
