Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Lx30h when it goes into rinse mode water comes back into rinse bucket solution any idea why? mike taylorwm@missouri.edu thanks for any help
2 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: hobart lx30h rinse additive is running all the
The main cause is the "anti flood" device at the bottom of the washer that detects a water leak "hose leak" etc. This device made up of a polystireen float and micro switch is a safety device and when activated puts the washer in pump out mode only. You need to look at the base of the washer and see if water leak has caused this. Rectify the cause "normaly hose or clamp" and this should clear the
Posted on Mar 21, 2010
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
My Maytag Centennial will not fill with water on the wash or rinse mode. I can hear it click to tell it to fill but it will not. It does spin. I do have water at the kitchen sink so I know it is not a...
your cold water line to the washer is most likly plugged.shut cold water valve of going to washer remove cold water line from washer clean screen in water inlet valve. the screen is in the valve were the line comes of washer.make sure you put the screen back in as it has to be there. flush out cold water line in bucket before putting it back on washer,, good luck thanks for voting
Mar 24, 2011 | Washing Machines
Hobart lx30h rinse additive is running all the
Mar 21, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
On Rinse nothing comes out?
Do you seem to end up with more water in the tray now then you did before this problem started? Does your coffee seem weaker then before? If so I have some ideas for you.
Mike
Apr 16, 2009 | Jura Capresso Impressa E75 Espresso &...
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Sep 17, 2008 | Dehumidifiers
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
65 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
