Question about Canon PIXMA MP780 All-In-One InkJet Printer
Suddenly it prints slowly and says error wrong cartridge
    President:
  • Canon Master
  • 2,017 Answers
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 29, 2010
Printer was working fine, suddenly prints very slowly. Tried uninstalling and re-installing. Still slow.
Hi
Thanks for trusting FIXYA for your problems
Its just the cartridge problem and needs to be replaced. Normally its with color cartridge but make sure and replace the faulty and it should be ok.
Align the print cartridges again to make sure its not the reason as this can also cause the printer to print slow.
Oct 28, 2012 | Hewlett Packard Printing & Imaging HP...
"Wrong cartridge" error when in fact it is the right cartridge
On this machine it means the printhead is bad. QY6-0049-000 around $40.00
Jul 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp officejet j4680, incompatible cartridge
It is not necessary to buy another cartridge my friend, you can repair it. let me show you how... just take a towel paper, pour some water on and slide the cartridge slowly on, repeat this action 3 times and then slide the cartridge on another towel paper without water slowly and get the cartridge back in the printer.
good luck
Jul 02, 2009 | HP Officejet J4680 InkJet Printer
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
Printing on tape
The print cartridge may be installed wrong or there may be a problem with the tape installation, or a part broken on the printer.All these factors can cause no printing
Jan 24, 2008 | Canon MP-11DX Calculator
Very slow printing
Try to make a photocopy first from the printer itself, if it can print faster then the problem is on the computer,if not then follow the steps below:
Clean the printheads, clean the nozzles, if it still print slowly, remove the cartridges and clean the nozzles. If these steps does not resolved the problem then try changing the cartridges, maybe there's something wrong with the cartridges itself. After changing the cartridges, try to print again, and if its still the same then just post it here and ill try to find another solution for you.
Jan 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
