Question about Dell Latitude E6400 ATG PC Notebook
I cannot open my laptop with control-alt-del. when I power on the laptop, I get a continuous high pitched alarm. also, the battery charge (lightening bolt icon) does not stay lit. Is it power adapter or battery or other?
    Sergeant:
    Novelist:
  • 179 Answers
It could be either or both. First, use a multimeter to check the power output from your adapter to see if it is within specification (your particular computer requires 19 VDC). If the voltage is low, you need a new adapter at least. The battery charge icon not staying lit can be because of a bad adapter, but also can be because of a damaged connection in the plug where the adapter jack plugs in. If you wiggle the plug, does the icon go on and off?
If you remove the battery from the computer and leave the adapter plugged in, does it make a difference?
Only more rarely is it the battery itself. Try the above first.
Posted on Dec 29, 2010
High pitch alarm sound when vehicle on or off
try disconnecting the battery and reconnecting
Dec 20, 2013 | Audi Cars & Trucks
I bought a brand new 170.00 battery for my Dell studio 1737 laptop. It continues to say plugged in, not charging. What can i do? I've tried plugging in and replugging in the charger.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Or you can visit http://www.batteriescenter.com.au/.
Jun 19, 2011 | Dell Studio 1737 (Studio 1737-RubyR) PC...
All my Dell power adapters are dying! I have 3 and none work now. The first one started saying it was not compatible, then the next one worked for a short period then the green light went out. I put one...
Yes! unfortunately it is, the reason why the power adapter has the high pitch noise is because the power supply is being loaded down by the motherboard, it may be due to the DC jack in the laptop or the charging circuits on the motherboard causing the problem. However there is one way to find out, remove the main battery to see if the high pitch noise goes away, if it does! it will prove where the problem is. It is also very possible that the battery is loading the whole circuitry, because it may have a high resistance short, enough to cook the power supply, I have seen this in very rare cases and is one for the books.
Mar 11, 2011 | Dell Inspiron 5100 Laptop
How do you reset your latptop?
You can perform a hard reset by pressing and holding the powered button for 5 seconds.
Please leave feed back if this helped you :)
Nov 12, 2010 | Computers & Internet
Can not restarted after putting it to sleep
pull the battery out, then back in and retry,
Look to see if you get a charging light when pluged in, if you dont then the power plug or power jack is bad and the battery cant charge
May 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
I forgot my password to my Acer Aspire 4520 laptop. How do I unlock it and reset the password?
at the time of login
press ctrl-alt-del this will change the way windows login
type in the user name Administrator and prerss enter
now go to control panel and double click user account and remove the password........do reply back
Oct 05, 2009 | Acer Aspire 4520-5582 Notebook
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Dell Latitude E6400 ATG  PC Notebook Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
