Question about Dell 946 All-In-One InkJet Printer
Printer will copy,but not from computer - Dell 946 All-In-One InkJet Printer
    President:
  • Dell Master
  • 2,022 Answers
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components.
Which is contains the hp director software. Which shows the scanning option For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Have a nice day and do not forget to rate please...!
Posted on Dec 29, 2010
I want to scan a copy to my computer. the error messae on my printer says no computer found.how do i connnect my printer to my computer
uninstall the printer driver then connect it with computer if computer detect the printer then install it and print the documents.
if computer not detect the printer then connection media like USB cable or wireless connectivity setting
Apr 17, 2015 | HP Photosmart 5510 Wireless e-All-in-One...
Type your problem for a solution... my lexmark is not printing or copying.
If you're not able to do a simply copy using the Copy button on the printer operator panel, please try the steps below to reset your printer:
  1. Disconnect the printer from your computer.
  2. Remove the sheets of paper from the feeder.
  3. Open the printer cover and remove the cartridges.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert the cartridges.
  7. Load some paper.
  8. Try to make a copy again using the Copy button on the printer.
  9. If copying is working fine, reconnect the printer to your computer.
  10. Before trying to send a new print job, make sure the print queue is clear. Then try to print a document from your computer.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Oct 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
Would like to use printer to copy only without a computer interface.
If the printer has a copy button then put the paper on the glass and hit copy, if not then you need the computer.
Feb 26, 2011 | Lexmark X1240 All-In-One InkJet Printer
How do you scan digit prints from my 5300 scanner/printer to put on email????????????
Hi. There are lot of way on how to transfer your documents from old compter to nerw computer. First, you may use extarnal harddrive and copy all the documents from old PC to external HD and copy it to new PC. Second, If computers are in a network you may access the old computer from the network using the new computer and copy the files. Third, you may burn all the files from the old computer and then copy it from the new computer. Fourth, you may also do direct cable (LAN) connection to copy files from your old computer.
Aug 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I cannot get the printer to copy anything, it just goes into the align mode. It will print things from my computer.
Start up your multi-function printer and computer. Wait until it has powered on completely before beginning.
Open the printer's lid and place your item on the copying surface with the side you want copied face-down on the glass. Double-check the alignment.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed.
Choose the kind of copy you want: black-and-white or color. You also may have to select the kind of paper that you are copying.
Size the copy to the page if desired. Some multi-function printers allow you to expand or shrink the original to fit different sizes of paper.
.Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Press the "Start" button. Other names for this might be the "Copy" or "Print" button.
Remove the pages as they are delivered from the printer's feeding mechanism.
Do not tug on the copies as they come out. Let them fall into your hands.
Take care.
May 15, 2010 | Office Equipment & Supplies
Do i need a computer to photo copy? i
No you should not need a computer use the photocopy function on a all in one printer. In any case you may be able to buy a just a copier without the print function cheaper. Remember ink in ink jet printers are expensive
Dec 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Nothing coming up on the copy
Hi There, when you mean copy, do you mean copying from the printer to the computer, or from the printer to paper. If from printer to paper, try checking the settings on the printer. It may be copying to your computer in a my pictures folder. Try that and see what happens.
Dec 02, 2009 | Lexmark X5150 All-In-One InkJet Printer
Copy will not work on printer itself
The 1150 is not a stand alone copier, the only way the copy function works is when the machine is connected to the computer and the program is running. I never liked that much here in the repair shop because in order to service it I have to connect to a computer.
Jul 21, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printer keeps printing the copy over and over and over
Shut down, unhook the USB cable, turn computer on, shut down, reconnect the USB cable, turn on computer.
Jan 03, 2009 | HP PSC 1210v All-In-One InkJet Printer
IS IT POSSIBLE TO GET A TEST PRINT OR SCAN TEST WITHOUT THE X1180 BEING CONNECTED TO A PC?
No, if you print or scan, you need always to store the file on a computer, and if you use copy function, you still need the computer, as copy function allowed on this printer is only Colour Copying with PC .
This printer cannot print, scan or copy if it is not connected to a computer.
Oct 10, 2008 | Lexmark Office Equipment & Supplies
Dell 946 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
