Question about Dell Dimension E310 PC Desktop
Where is the USB port located on my Dell monitor?
    Sergeant:
  • 320 Answers
Hi bonit,
What I really need to help you is the brand and model of the monitor. I looked up the specs for your computer and found nothing about a specific monitor that was sold with that unit. If you can tell me the brand and model number of the monitor I might be able to answer your question.
Another question I have is what do you want to use the USB port on your monitor for. There are very few monitors that support USB video feeds, most use VGA, DVI, or some high end monitor even have an HDMI connection. In my monitor I have a USB hub built in, but that has nothing to do with the video, it allows me to connect multi USB devices.
If you can give me more info I can help you.
Posted on Dec 29, 2010
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
Help, can't seem to get the USB ports on my monitor to work again. I have the following dell monitor 1704fpt 17in. running windows XP Pro sp. 2
Since the USB ports on this monitor are just the powered USB Hub, you should try it with another PC if you know for sure that the USB port of the PC taht is feeding this Powered USB Hub on the monitor are OK, also check the cable.
The USB board replacement for thsi will not be woth it. Also check for 5vdc on PIN1 of the USB port.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%201704FPT/
May 05, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Why don't my USB ports on my monitor work
1) good USB cable from Monitor USB input port to PC USB port?
2) Check pin 1 of the USB port, you should have 5vdc.
3) Your monitor's USB ports are basically the powered USB hub, but it must be connected to the PC USB port.
Jan 25, 2010 | Dell E176FP 17" LCD Monitor
Usb ports on 1703fpt do not work
you have to connect the monitor with a usb cable to your computer, then you can use its usb ports, it's just a hub.
Mar 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Monitor usb
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Feb 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell Dimension E310 PC Desktop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
