Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG LDS 5811 Dishwasher has white film everywhere.
LG LDS5811 has white film on dishes and on walls. I tried replacing soap, jet clean but problem persists.
  • Anonymous Nov 13, 2008
    My LG dishwasher leaves a white greasy substance on plastics (Tupperware) that I wash, it is not on the glasses or dishes. It is in the bottom of the dishwasher all over the mesh and bottom drain. Help!!!!
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a filter designed just for this type of problem. it filters the water going into your dishwasher and you will be amazed how clean they look immediately. it is very affordable. get it at www.dishwasherfilter.com
Posted on Mar 18, 2009
  • 489 Answers
You may have a water issue.  Be sure that the water line is connected to the hot water pipes, not cold water.  If your dishwasher is connected to the cold water, the soap residue will occur because it cannot dissolve in cold water properly.
Is your water very hard??  If so, you may need to get a water softener to remove the hard scales.
Posted on Jul 23, 2008
LG dishwasher LDS 5811 WW smells really bad has a slime film everywhere it was coated all over the upper arm and lower spray arm- dishes are not getting clean- and it smells so bad- any ideas?
it sounds like the problem is your water. go to www.dishwasherfilter.com and check out the dishwasher filtration system. it will solve your problem and works amazing. it is guaranteed or your money back.
May 14, 2013 | Dishwashers
Lds5811 pf error
PF failure is a pressure switch there is usually 2 switchs p1/p2 sometimes get full of water and trip the breaker.May also be a draining problem,check all hoses for obsrtuctions,kinks etc.Replace both pressure switchs and see how you go.
Feb 26, 2012 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Not good washing
You are either not using enough of the wash chemical or you need a product like Jet Dri...what you are seeing is mineral deposits.  Make sure your water temperature is hot enough.  If not sure, use the cycle which heats the water.
Nov 15, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap left in the dish
With the LG LDS5811 dishwasher and other water/energy saving dishwashers, they are VERY ineffective with untra cheap powder detergent. Switching to Electrosol or Cascade has solved the problem -- and don't use too much.
If you add a whole house water softener, you will be AMAZED how much better your dishwasher and clothes washer work -- especially if your cut down on the amount of detergent your use.
Oh, never use gel or tablets in your diswasher. Ever.
if the problem with the detergent dispenser not opening is a seperate problem. Recommend you submit a seperate problem/question.
Good Luck!
Aug 26, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
304 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
