Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My sony wega 42" rear
  • 1,557 Answers
It depends on the type of blue ray player you buy some only have hdmi output others have standard rca - yellow - red - white this is the one you need
Posted on Dec 29, 2010
The provided HDMI female receptacle is being used by the DirecTV hookup. Is there an adapter, from coaxial cable to HDMI (male receptacle)?
HDMI cable has several diferential digital (LVDS) signals that also carry digital audio on them, not compatible with coax!
Jan 19, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony wega 50" only has one HDMI and it is plugged into the HD cable box. I need another one for the bluray DVD player
we have replaced our optical block and the lamp twice-first time it exploded inside the tv? now the tv doesn\'t work for cable but we can use the piss poor cloudy optical block again using hd antenna or thru xbox internet - this tv is GARBAGE end of story! I will NEVER purchase a SONY product ever again - they are basically all the same like our Food industry they just slap some other company name on the final product - we were ripped off bad for this tv paid 3,000 piece of garbage!!!
Jan 09, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Connected my laptop to sony wega tv using hdmi but get no sound on tv
HDMI is prone to this--If you connected with the set (TV) on you may have caused this issue.
In our shop we get a lot of this and if a box was being used (cable HDMI) the box needs to be rebooted.
I would at least try unplugging the TV from power--wait and try to boot it up again(set with power disconnected and then powered again will try).
Restart the laptop, with the cables (HDMI) REMOVED AND THEN INSTALLED AGAIN BEFORE YOU APPLY POWER TO THE SET.
This may or may not help but is worth trying.
Failing this it may be a setting in the laptop or a mismatch between the two units.
Apr 02, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
What is wrong with my tube television 42 " sony tv? please help
need Sony repair tips? visit this site
http://www.servicetron.com/sony-tv-tips-1.html
Feb 17, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
I have a sony wega KDF42WE655 TV(42 inch). It has a HDMI port I recently bought a PS3 and hooked it up to the TV. With the HDMI port connected I do not get any picture or sound. Attempts of rebooting...
There is a separate IC on the main board that does nothing but process the HDMI signal, basically if your using the cable, AVI or any other input other than HDMI and chances are that is bad, it can be replaced if you have a lot of electronic experience, its a $3 chip but its not easy to replace..I would replace the main board if you can find one, sometimes main boards are hard to find..below is a link to the service manual.
Sony KDF 42WE655 Service Manual
Nov 23, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have comcast cable HD. What setting do I have to have on the tv?
Try connecting the HDMI output from your Comcast Set-top box to the HDMI input on your set. Then select the appropriate HDMI input from the menu.
Jun 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
569 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
