Question about Belkin Computers & Internet
How do i enable wep security on my belkin wireless routeron my pc & what do i do for 2 laptops
  • Belkin Master
  • 19,396 Answers
Check
Setting up wireless security
Belkin : Support : Configuring Wireless Security
Enable wireless and wireless security on your Belkin ...
Generally access the router control panel panel putting router ip number on internet explorer bar. You will be asked for passwords. Check IP number and password for your model on manual.
On panel go to wireless then security, you find menus at left and top bar of the router control page in internet explorer.
Set encryption and input the password.
Do save all command (button at bottom of page).
set wep password also on wireless networked computers.
Posted on Jul 07, 2008
I was on my ds and i went to Nintendo wi fi settings and it asked me to input my wep key and now i cant figure it out.
BELKIN ::::
Hi ,
By Default the security in the Belkin is WPA and unfortunately the DS Doesnt support this
To enable WEP in the Belkin follow the Steps Below
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Feb 13, 2011 | Belkin Basic Wireless Router
I am able to get on the internet but i am not able to use my wireless router do to the securtity is on. How do I turn it off so I can operate my laptop
Hi Clark,
I got your issue, Inorder to enable the security on your belkin router
1. Open Internet explorer and in the address bar type 192.168.2.1 and hit enter
2. You will be logged into the belkin router setup,it will ask for login password, leave it blank and click on submit
3. In the left side Under WIRELESS , click on SECURITY
4. If the security mode says disabled, click on drop down arrow and select 64 bit WEP and it will show up KEY1, in key 1 type any ten digit number (2nos in each box) and apply changes
From now your network is secured with WEP security.
Thanks & Regards,
Prema.
Oct 18, 2010 | Belkin (F5D8231-4) Wireless Router...
How can I retrive my password or wep key off my Belkin wirelless router I bought a new laptop and can't acess my router
Use a wired computer to access the setup page of the router.
On the browser's address bar, type 192.168.2.1.
By default, leave the password field blank.
Once on the setup page of the router, go to Wireless then Security. You can get the WEP key from this screen.
Or if you would like to turn off wireless security, just change the security mode.
However, I strongly suggest to enable wireless security so that other people will not be able to use your wireless network.
I hope this helps!
May 14, 2010 | Belkin (F5D8231-4) Wireless Router...
Once I have enabled WEP, how do I set up the wireless clients to use the router? I have no idea how to configure the clients. I have a WIndows XP, 2 Vista machines and a Windows 7 laptop I need to...
Just connect to the network... Simply open the icon in the far bottom right hand corner ; with the 2 double little PC icon; WLAN icon . Right click >> Then "Connect to a Network" >> Look for your own wireless network >> then connect >> will ask for the WEP key - log it in >> Then Connect.
Mar 27, 2010 | Belkin (F5D5231-4) Router
I have a belkin wireless adaptor, but a D-Link router, how do i link them!?!?????
You need to know the wireless settings on the Dlink router first. To check the wireless settings, you need to use a wired computer to the router.
Then in the address bar of a web browser (Internet explorer or firefox), type 192.168.0.1.
By default, the user name is Admin and leave the password empty.
Go to Wireless Settings. Take note of the following:
1. Enable wireless should be checked.
2. Take note of the wireless network name. You may change this into a unique name so that you can easily determine your own wireless network.
3. Visibility status should be Visible.
4. Under Wireless security mode, it depends on you if you would like to enable it or not. If you would like to enable the security, just select WEP. Then enter the WEP Key 1. This is like a password for your wireless network, use letters from A-F and numbers from 0-9.
Then click Save Settings.
Once the belkin wireless adapter is installed properly on your computer, there are 2 ways to connect to your wireless network.
Either you use the Belkin WLAN monitor or the Wireless network connection (for Windows OS). When you view the available networks or Site survey, you will see the wireless network name on your router. It will prompt you for a network key if wireless security is enabled.
Make sure you enter the WEP key 1 in your router. This is case sensitive.
I hope this helps! Good luck!
Mar 22, 2010 | D-Link DIR-615 Wireless Router
How do i secure my belikn from outsiders using it
Hi Friend,
U need to make your wireless network a security enabled network & don't share the wireless network key to a unreliable person.
Steps to create a security enabled wireless network:-
1> login to router setup page;bydefault ip address of belkin router is 192.168.0.1/192.168.2.1
2> Open a internet browser on a hardwired desktop/laptop connected to your router,clear the address bar completely and then type 192.168.0.1 or, 192.168.2.1<it depends on your model no of your router>
3> Go to Wireless Tab,changed the wireless network name(SSID)
4> Change the wireless network key as well;it will be good if you use WEP key if you old XP computer,otherwise use WPA-TKIP if you vista/win7 computers
5> Lastly on your computers,you have to seach wireless network name & give the wireless network key(for the very first time)
In case of any clarity feel free to contact belkin tech support
Mar 19, 2010 | Belkin (F5D9230-4) Wireless Router...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Belkin g + mimo and xbox 360
are you typing the correct upper or lower case and not confusing zeros with the letter 'O'
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g4 router
1.go to routers' setup, enable wep security and in wep menu insert a number about 8 digits
2.then go to wireless connection on your pc and in security menu enable it and check wep key
Nov 25, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
126 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
