Question about Bryant Heating & Cooling
I can not control my furnace. The handyman pulled all the control wires off trying to fix it. is there a standard way of wiring the control of a furnace. I need to hook up the Bryant Magnetic Diaphragm Valve to the thermostat, power source, hi temp safety switch and pilot. The system runs on natural gas. Valve is model ib634. Thank you for your assistance. Sincerely, Jack Cohen, Mananger Apex Property Manangement, LLC tel: 610-656-2401 e: mrjackco1@comcast.net
  • Bryant Master
  • 7,990 Answers
Hire a pro. safer
Posted on Jun 08, 2017
the dr
  • 447 Answers
SOURCE: Carrier Natural Gas Furnace/Air Conditioner, Model 518CXX036000MBAA
Is this a package unit??? Or is it inside the home?? How old is the furnace. The first thing to do is axcess the fan and see if it is controlled by a computer or its old enough to have a fan switch. Trace the red wire from the fan mtr that should take you to the fan switch
Posted on Dec 01, 2007
  • 15 Answers
SOURCE: Carrier Performance Edge Programmable Thermostat
Are you a qualified refridgerator mechanic with an eletrical liscence? If not get someone who is because doing it yourself will not only void the warranty of the unit but will also void your house and contense insurance in the event of a fire.
Posted on Mar 16, 2008
  • 360 Answers
SOURCE: Code #33 on Bryant 355MAV 90i Furnace
Make sure the unit is properly set up (jetted/orifices) for LP. It sounds to me like the unit is setup for natural gas and is being used on propane.
Posted on Mar 01, 2009
electrodynam
  • 35 Answers
SOURCE: bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Posted on Mar 19, 2009
  • 16 Answers
SOURCE: Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Posted on Apr 07, 2009
The blower motor does not come on when we turn the air conditoner on, but does come on when the furnace come on it blows out fine. it is an american standard. the unit on the outside is running strong,...
Hello, turn off power to the furnace and remove the thermostat, then take the R and W Wires and put a jumper wire between them, then turn power back on if this turms on the furnace then you have a bad thermostat if it does not it is a problem with the integrated control board or possibly a low voltqge wire is loose.
Jun 20, 2011 | American Standard WCZ036F Air Conditioner
How doI replace the motherboard on a American Standard Freedom 80?
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Mar 02, 2011 | Heating & Cooling
Just moved into this house and notice the furnace not working right It is and older unit know name or writing on it I rehooked up wiring to it but now blower run all the time and the only to shut off is...
Older furnaces used to have a fan switch that read winter or summer, or auto and on. You should also have a fused switch to the furnace, wiring runs black to the switch thru the fuse and to the furnace black wire. White wire is straight to furnace from electrical panel. This is for power feed to furnace only. Now the thermostat is red to the transformer white to white. This was a very simple old furnace they had very little safety devises. The fan switch was an older high end model so you could blow the cool air from the basement thru out the whole house in the summer, and the fan ran constantly.
Dec 20, 2010 | Heating & Cooling
How to set a NOMA HTM311A thermostat
Go to the furnace, and see what the black is connected to. If it is not the Y terminal, disconnect it from the Y terminal at the thermostat. While you have the furnace open, check for a blown fuse inline to the transformer or on the control board. If the black was connected to the common or the transformer, and you connected it to the Y, and turned the thermostat to cool, you would have a direct short across the transformer output. You can use a black wire to control the A/C, but both ends need to be connected to a Y terminal.
If you still remember the where the 4 wires were connected to the White Roger thermostat, take note of the name of the terminals the 4 wires are connected to. That may help as sometime the colour of the wires are not always correct.
Or you really want to test it out:
connect RED wire to GREEN wire should turn on the fan
connect RED wire to WHITE wire should turn on the heat
Did you disconnect the power at the furnace first? Maybe you blew a low voltage fuse.
Make sure you increase the heat setting to go above the room temperature.
Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
R (red) or Rh (Red heat) 24 volts from equipment.
Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
W (White) sends 24 volts to furnace control to start the heating cycle.
W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
C (common) most often brown but can also be black or other color available to installer.
O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Heating & Cooling
Furnace locks out because of twinning polarity
Usually a polarity problem is fixed by reversing the wires that run to the power supply to the unit.First, shut off the breaker that feeds power to the furnace. Most of the time, there will be one black, and one white Unhook those, switch the wires around, use new wire nuts to wire them back together. Hope this helps.
Nov 08, 2009 | American Standard 40 G Natural Gas Water...
Wired Xbox 360 Controller is loose where it connects into the top
You can try using a little bit of Loctite Handyman Glue if the rubber piece is the only thing that is loose. if the wires themselves are loose inside the controller, i would suggest buying a New/Used controller instead opening it up yourself (unless you work on controllers and other small computerized objects)
Oct 05, 2009 | Microsoft Xbox 360 Controller
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Jun 02, 2009 | Carrier Heating & Cooling
I need help with my central heat and air unit, it has a heat pump. the model number is GQ3RA-036K. I am changing the theromstat out and the wires are connected to it. there are eight wire colors that are...
May 07, 2009 | Heating & Cooling
Furnace problem
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles down...it does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Aug 21, 2007 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
