Question about ViewSonic Computers & Internet
The monitor makes a clicking sound but does not go on.
  • ViewSonic Master
  • 32,281 Answers
This monitor is faulty, the costs of LCD monitors are low and the cost of repairing your monitor may not be worth the trouble.
Posted on Dec 29, 2010
I want to make my monitor speakers play sound
Make sure that you have the cable plugged into the monitor and going to the computer if there is one. Some older model monitors operated that way.
Click Start/Control Panel and check your Audio/Sound properties to make sure the drivers are ok. Look for either sound or audio or device manager under the control panel.
Does the sound work for external speakers? Does the sound work for a headphone? Did the computer and monitor come together when you purchased it?
Mar 24, 2012 | HP Computers & Internet
How do you fix a hp1907 when the vol says it works but it doesnt
here are the options:
1.Make sure you have the audio cable connected from the monitor to the computer( look for a green connection on your desktop or output audio or a sign with headphones and connect the audio to there.
2. Install the monitor software or reinstall
3. At the bottom right hand corner right click on the volume icon and click volume option. if can't find it there go to control panel then> click on hardware and sound then> click sound then> click on the tap PLAYBACK.
You should have some options. Click on your monitor name and set as default.
Let me know any of this option work.
Mar 04, 2011 | HP w1907 LCD Monitor
No sound coming out of my hp monitor speakers. Monitor shows speakers are on and not muted. I have a green cord connected from my monitor to my desktop.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | HP (PP036AA) Computer Speakers
My computer has no audio
I have this monitor.
You need to click on the little audio (speaker ) button then use the + - to advance the volume to its proper setting.
You also need to have the audio jack connected to the correct line out on your sound card.
if you have the audio setting on your computer set to mute, or turned right down, you will not hear sound through the monitor speakers.
double click on the icon in your task bar that controls your sound. make sure it is turned up, then try to the settings on the monitor.
May 03, 2010 | HP w1907 LCD Monitor
No sound
Is there a rca/headphone jack for the monitor? Make sure that the jack is plugged into the computer's audio out rca jack. A driver should not be needed for the audio on the monitor. If the jack is plugged in make sure that the audio is not muted on the computer. Right click on the speaker icon in the right bottom of the screen on the windows tray nand open the sound mixer. Make sure all the sounds are on. Then check the monitor settings and make sure the sound is on and not muted thru the monitor buttons. If the cable is good and all these things are ok then the internal sound amp in the monitor might be bad.
Sep 08, 2009 | Optiquest Computers & Internet
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dec 22, 2008 | HP vs15 15"LCD Flat Panel Monitor
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
Worldvet
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Computers & Internet Logo
61 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
