Question about Kenmore Oasis HE 27082 Top Load Washer
How do I get the F1 code to go away? It pops up before the machine will start washing and then again before it will start rinsing. (Kenmore Elite) Oasis HE
    President:
  • 1,554 Answers
It sounds like the error code F1 appears whenever the machine is filling. The machine/motor control senses an error in the signal coming the pressure sensor circuit. Either there is an air leak and/or moisture is present in the pressure sensor hose, lint and/or flashing in the air dome hose connection port, or the machine/motor control is malfunctioning.
Remove the three screws from the rear of the console assembly then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Posted on Dec 29, 2010
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite 27032/27042 F1 code appears at beginning of wash cycle I redistribute the colthes once or twice and it continues to fill but sometimes does the same in rinse cycle
You have something stuck in your pump, turn machine on it's side and take the bottom off you will see the pump, take the bottom off of pump and remove whatever is stuck, just had this problem today!!
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Kenmore Oasis HE 27082 Top Load Washer Logo
647 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
