Question about ViewSonic ViewMate CW2206 DHCW2206 Keyboard/Mouse
Mouse out of function
Cw2206 mouse out of function
  • bluebuddha Jan 13, 2009
    i have a viewsonic cw2206 wieless mouse nd keyboard, the keyboard works but not the mouse will not sinc..any help?
Changed batteries on keyboard and now wont sync. Cant see a sync button on the keyboard so dont no wat to do
Hi.
You should find the sync/connect button underneath the keyboard. You must also press the button on the receiver.
Regards.
Jun 08, 2011 | ViewSonic ViewMate CW2206 DHCW2206...
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
Windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
Apr 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Mouse pad will not work...only external mouse works....even though mouse is saying enabled on control panel
A laptop has a second function. It may be that you had accidentally clicked on Fn F7 or other laptops may have different Function to disable the mouse pad. You can determine that it is the mouse pad function because it shows a picture of a "hand in a square". To enable it, just Hold Fn then click F7 or different function.
Feb 03, 2010 | BenQ Joybook 5100U Notebook
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
The machine has got coruppted
you should be able to do a restore on the system or install a fresh copy of xp tablet on it
Jul 20, 2009 | ViewSonic (CW2206) Keyboard
Mouse pad not working - external mouse works fine,
try to re-intall your mouse pad driver and update your machine's bios.
if still doesn't work then you mouse is faulty and might need to replace.
Jun 30, 2009 | Computers & Internet
Boot Manager
Did you enable USB Legacy support in the bios?, if not, that should fixit
Sep 06, 2008 | ViewSonic ViewMate CW2206 DHCW2206...
Mouse not working
Hai Charles
In the Device Manager, check the mouse section for any ? question mark over your mouse model. If so, right click the mouse model, select properties,and in the driver tab, click update driver.
It will make your mouse work perfect.
Rabby
Jun 16, 2008 | Logitech MX1000 Laser Cordless...
Not responding to movement
Dear Stef, First try replacing the mouse's batteries, if this fails then try resetting it using the reset button - both on the mouse and the receiver. If you experience trouble resetting, you may try to disconnect the receiver and the mouse physically. Unplug the receiver and take off the mouse's batteries and then reconnect them.
Jan 09, 2006 | ViewSonic (CW2206) Keyboard
ViewSonic ViewMate CW2206 DHCW2206 Keyboard/Mouse Logo
73 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
