Question about Janome Memory Craft 9000 Computerized Sewing Machine
Machine jamed and now will not turn on. Several years ago the same thing happened and they said they replaced a fuse?
Softwear problum
Posted on Dec 29, 2010
Reset master code for viking platinum 775
I don't know if anyone ever answered your question: but I've found that when this happens if you 1. Turn off your machine and then 2.Unplug it from the wall. Then 3. Replug it and turn the machine back on. Something about the process triggers the machine. Don't know how long the "fix" will last, since mine just started doing the same thing. But for now, it's back to responding to stitches being selected. Good luck! ~Wende at Mireio
May 18, 2013 | Sewing Machines
I have an Elna 1010. I have not used it for several years. When I turned it on and pressed the foot petal all the way down, it sounded like something was going to happen, but nothing did. I am in the...
If you have not used it for several years and now not getting any drive action, then it is possible one of the gears inside it has failed, broken or siezed up. This would be inside the free arm or near the motor probably.
I would suggest that you take it to a sewing machine repair shop and get it serviced, all machine manufacturer's recommend a service every 1-2 years to lube internally, clean out and address any issues. Just the same as getting the car serviced.
My local shop charges $80 for a service/clean plus any parts to be replaced, well worth the money in my humble opinion.
Apr 06, 2011 | Elna 1010
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
I purchased singer 591 from a commercial manufacturing comp. About 3 years ago for my fiance to use. She doesn't need it anymore so I'll sell it. Thing is I can't turn this machine on to show potential...
A 591 is a flat bed industial machine, that came out with a clutch motor. Unless it has been changed to a servo motor. A clutch motor when turned on will will spool up to speed and you will hear it run. A servo motor makes no sound until you move the foot leaver.
If you hit the switch and nothing happens even when you move the foot feed, check your electical connections.
May 19, 2010 | Singer Quantum XL-5000 Computerized Sewing...
Janome 10000 i year ago shaft bushing was replaced . After getting machine back Lcd screen acted up did not think much about it because it was not consistant.less than a year later with very little use...
I have been dealing with machines of various types all my working life. I have learned coincidences do happen - but not very often.
My instinct, in your case, strongly suggests the problems are connected. My instinct is to suggest you take your machine elsewhere for maintenance - somewhere that employs experienced and qualified engineers and has a boss that allows them adequate time to do their work properly.
I am completely guessing but if the replaced bushing was broached or line-reamed or the correct service tool was used for fitting, the dc motor might have survived (these are usually almost bullet-proof). I guess if the dismantling and reassembly was suitably careful, the lcd screen would probably have been in the same condition when it arrive back from repair as when it was sent.
Jun 03, 2017 | Janome Memory Craft 10000
My Janome 9000 also quit a few months ago, took it to repair shop and they replaced a fuse. Have only used it about 2hrs since and it did the same thing again. So we decided to replace fuse...
Your fuse is blowing because there is a bind in the machine. Did they service the machine when they replaced the fuse? If yes, it should be under warranty. Best guess is that it is tight from lack of lubrication, usually at the bushing nearest the hand wheel.
sewman7
May 13, 2009 | Janome Memory Craft 9000 Computerized...
It jams up
When that happened to me I had to replace the bobbin case-- (the peice of the machine the bobbin goes in.) It wasn't a Brother, though. I'd take it back to the repair shop and tell them it's still doing it.
Aug 10, 2008 | Brother CS-6000
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
59 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
