Question about Troy Bilt 5.5hp Self Propelled Mower
Have a Troy ilt with the Honda motor. Started easy ran a bit then started blowing smoke out the exhaust. Head gasket?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly,
I doubt it is a head gasket. First check to make sure the oil level is not over-serviced. Then if the oil level is correct and after 10 minutes it is still smoking you will have to remove the breather assy on the side of the head where the valves are and clean the reeds with solvent. (might require a good soaking) The crankcase is over-pressurizing causing oil blow by via the valve stems. Sometimes you will experience up to 4 minutes of oil smoke if you have tipped the mower in any direction other than flat. If that is what caused your oild smoke episode it will clear and there is nothing you need to do other than let the engine run. If it easily repeats the smoking after running for a bit routine you most likely have a sticking crankcase / valve breather reed. Cleaning it usually will correct the excess smoke problem. You should be able to remove the breather without removing the carb for cleaning.
If you have a head gasket failure the engine simply will not start. Since the engine is an overhead valve design it is possible to have a head gasket fail but..... highly unlikely unless someone has done recent maintenance on the valves and disturbed the head gasket. I have not seen a honda head gasket failure that was not induced by someone doing maintenance on a cylinder head. The design of the head even with minimal bolt tightening torque will allow the engine to run just fine and not ruin the head gasket.
Should you require more information I will need your exact engine model number from the crankcase of your engine just aft of the oil fill tube on the base of the crankcase.
Thanks for choosing FixYa,
Kelly
Posted on Dec 29, 2010
CEL blinking, rough idle, smoke blowing out exhaust: help!
White smoke is generally head gasket blown. Water in the exhaust.
Apr 16, 2017 | 1999 Subaru Forester
Burning oil
Assuming its a briggs and stratton
kohlers have hydraulic valves
check its not overfull of oil
smell the oil does it smell like gas?
if so remove carb. clean thoroghly and drain and refill oil
check valve clearance .004 both exhaust and intake (cold engine)
valve cover gasket could be leaking on the exhaust
could have a partially blown or blown head gasket also
Jun 13, 2013 | Cub Cadet Garden
My 97 honda accord is blowing white smoke and running rough then i went to start it now it wont start
Sounds like either a blown motor (rings need replaced) or a bad head gasket or cracked head.
If the rings are bad your car would have felt like it was losing power because the engine will no longer have the same high compression that it's required to turn the wheels. You may have heard your engine knocking or seen a light blue colored smoke coming from your exhaust as a result of your engine burning up oil in the combustion chamber from the rings leaking.
If your head gasket is leaking or your head is cracked you'd likely find milky looking oil when you drain your oil from water/antifreeze being mixed in and noticed a white smoke coming from your exhaust that is actually water vapor coming through the exhaust.
If your car was running rough when you last shut it off try pulling all of your spark plugs and either cleaning them or replacing them all. A bad head gasket or bad rings can both foul spark plugs. A car will run rough with 1 or 2 fouled plugs, but once enough foul it will no longer run at all just sit and crank over. If changing the plugs get's it started for ya, check your tailpipe first for water, if nothing, change your oil. If no signs of water/antifreeze or milky colored oil then it's probably rings.
Aug 27, 2012 | 1997 Honda Accord
1987 toyota pickup with 22r keeps blowing head gasket
Your head bolts are stretched, when it got hot it weakened the metal in the bolts which means that the bolts cannot hold the needed tension on the head. Replace the bolts and you will stop blowing head gaskets. Also use Genuine Toyota head gasket, It will be a bit dearer but they are much better than aftermarket options.
Mar 07, 2012 | 1987 Toyota Pickup
White smoke coming out tailpipe
If your intake gaskets are leaking, when you dump soapy water on the gasket, it should bubble like crazy ( when it's running). If you can, run it with the rad cap off and watch for bubbles. If it keeps bubbling, you probably have a head gasket problem.
May 14, 2009 | 1996 Chevrolet Cavalier
Dodge caravan starting problems
hate to tell you this... it does sound like a blown head gasket
Robert
Jan 27, 2009 | 1996 Dodge Caravan
Troy Bilt 5.5hp Self Propelled Mower Logo
358 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
