Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Red "lamp" light stays on
    Problem Solver:
  • 5 Answers
Red light indicates the lamp has failed to light. You may just need to buy a new lamp. If that does not help then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Posted on Jan 30, 2011
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
The "lamp" light keeps blinking red. Does this
The lamp life becomes 0%, when used
for approximately 4,000 hours with "Eco
Mode" or when used for approximately
2,000 hours with "Standard Mode" (see
page 43).
When the remaining lamp life becomes
5% or less, " " (yellow) will be displayed
on the screen. When the percentage becomes
0%, " " will change to " " (red),
the lamp will automatically turn off and
then the projector will automatically enter
the standby mode. At this time, the
lamp indicator will illuminate in red.
If you try to turn on the projector a fourth
time without replacing the lamp, the projector
will not turn on.
If you require the manual to help with changing the bulb, send me an email to LBrown18062@hotmail.com Put SHARP PG-B10S in the subject line. I will send it to you right away. Lawrence Brown
Oct 26, 2011 | Sharp Notevision PG-B10S Multimedia...
SOUND WORKS BUT SCREEN STAYS BLANK/BLACK AND LAMP LIGHT STAYS ON CONSTANTLY I CHANGED THE LAMP AND THE RED LAMP LIGHT STAYS ON AND PICTURE STILL BLANK
Replacing lamps can be tricky. Make sure that the lamp is securely installed and you have returned all screws to their same position. Double check latches and doors; if they are not secured properly then the lamp sensor will not recognize that the lamp has been changed. Also, refer to your manual for lamp replacement procedure you may be required to press a series of buttons on the remote or TV control panel to reset the lamp.
Mar 03, 2011 | Philips 60PL9200D Projection Televisions
When i turn on my 50 " dlp it will stay on for about a minute then the screen goes black but the volume stays on. The red light by the power button then comes on. What do I need to do?
brad amie bi,
It certainly sounds like the lamp needs replaced. If your unit is more than 3 years old I would bet on it. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which addresses all the problems of replacement and also where to get a quality lamp at a good price.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 09, 2010 | Philips 50PL9126D/37B 50" DLP TV
When i turn the tv on the screen stays black and the light on the front lights up red on the Lamp button?
Lamp light lit, that means TV needs new lamp.
Replace lamp in TV as existing lamp is dead/ broken.
Thanks.
Dec 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Red light status stays on, no screen....unplug for one minute then tv comes back on.....this has happened a few times...what is up?
If the red light is the lamp light then the projector lamp is defective.
915P049010 If your model is WD-Y57
Jul 07, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
No picture/ no sound
Guest= Yours seems to be your lamp needs replacing, the buzzing is the lamp inverter trying to start the lamp and the lamp says NO.
Mar 15, 2009 | Hitachi 50VS69 50" Projection HDTV
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
610 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
