Question about Tippmann 98 Custom Act Paintball Gun
Can cold weather cause your gun to leak CO2? Because i was out playing paintball in the snow and it started to leak but when i took it inside and took it apart and put it back together it was working fine again and i didnt make any repairs at all.
    Novelist:
    Scholar:
  • 111 Answers
You are correct. Cold (and heat) play a part in expanding the parts of your marker. In cold weather, plus the coldness of the co2 working through it, the various parts can and will expand and contract at different rates. It only takes a fraction of inch to leak.
First thing is to make sure you have thoroughly cleaned and LUBED your marker. Lubrication... what kind of oil are you using? Some general purpose oils may work well enough in better weather, but in cold weather, and especially when using co2, you would be well advised to find and use an oil specific to paintball markers. These are manufactured with COLD in mind and will continue to work where others will gel up.
So yes, you are correct in your assessment. Keep your marker covered up when you're at the staging area... uncover it to chrono or test fire it at the range.. or when you get ready to roll out to the field. Use a good, paintball-specific lube (and keep it clean and lubed).
Also... an o-ring isn't just an o-ring. They have different densities and much like the proper lube, you need o-rings that are specific to the task at hand. Cold is a killer and it loves to mess with rubber and plastic. An o-ring that's become hard and brittle can't do a good job, so don't get o-rings from just any old place because they're cheap and look like they'll fit. Use good parts, good lube, and you should get some better performance out there.
Good luck... play hard, play safe, play with honor!
:o)
Posted on Jan 04, 2011
In Paintballing what is the difference between nitrogen (N2) and CO2 tanks?
CO2 tanks are composed of liquid carbon dioxide and are used for many scenario and recreation players. When the trigger is pulled, the liquid CO2 is converted to a gas, and this expansion of gas propels the paintball forward at 800-850 psi. CO2 tanks do not work as well in colder weather or for fully automatic paintball guns
Jan 17, 2013 | Sport & Outdoor - Others
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Feb 17, 2011 | Tippmann 98 Custom Act Paintball Gun
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
I got a co2 leak
The A5 standard is a pretty compact gun depending on the place of the leak I could assist you better. In any case you best chance is to check for leaks in the o-rings at the CO2 bottle, at the regulator.
Jan 12, 2011 | Tippmann A 5 Standard Paintball Gun
When i screw my tank on the CO2 goes right through the gun and out the barrel
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
Play hard, play safe, play with honor!
8^)
Nov 07, 2010 | Tippmann 98 Custom Act Paintball Gun
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
As soon as I screw on the CO2 supply cylinder, I hear air leaking internally. The last time I used it, it worked perfectly. Any ideas?
O-ring. If it is leaking near the tank, it is the o-ring on the tank. Otherwise, it could be one of many o-rings inside the marker. I would take it to a gunsmith and get all the o-rings swapped out.
Mar 01, 2010 | Tippmann 98 Custom Act Paintball Gun
In cold weather it wont fire, it acts like its running out of co2 it goes full auto.
make sure you replace all of the internal o-rings for commpression. one may be worn slightly and contracts when cold allowing gas to escape
Jan 09, 2010 | Tippmann 98 Custom Act Paintball Gun
Tippmann 98 Custom Act Paintball Gun Logo
159 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Vickie Miller
Vickie Miller
Level 1 Expert
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
