Question about Brother IntelliFax-4100e Fax
Printer is working Fine but Fax didn't work at all. Didn't pick up signal at all. keep ringing but not picking up... Copy function is not working at all. Press # of copy and press copy button it keep saying enter # of copy... Do i have to reset machine or should I replace it?
  • 1,472 Answers
Irene8801
It is possible that it is a problem with the phone line. Do you use this line for faxing only or do you have a normal phone on the same line. Also if the fax has a phone on it try calling another phone.
Let me know what happens
Issken
http://www.fixya.com/users/issken
Posted on Dec 29, 2010
Answ/fax do not work
Maybe it's not set to answer?
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Receive Mode
Make sure it's set to Fax mode.
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Ring To Answer
Pick the number of rings you want before the fax picks up.
Save and exit.
Apr 22, 2015 | Samsung C460FW Multifunction Printer...
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How to receive a fax
  1. Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to receive fax
Instructions Things You'll Need:
  • Phone line
  • Multi-function printer
  1. Step 1 Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Step 2 Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Step 3 Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Step 4 Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Step 5 Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Step 6 Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Step 7 Set the desired print quality, and you are ready to receive faxes.
You should be all set now to receive faxes.
Aug 06, 2010 | HP Officejet 4355 All-In-One InkJet...
I have a (time Warner) package deal that consist of cable vision internet telephone & voicemail. I am trying to get the fax machine to work along with these items. My voice mail picks up on the 5th...
Here's the link to download the Lexmark X4270 User's Guide: http://bit.ly/cNbUKo. If you prefer to have the printer pick up faxes automatically, I suggest you configure the printer to pickup after the 2nd or 3rd ring before your voicemail picks it up. On the User's Guide, go to Faxing, Receiving a Fax for the instructions. For more info about the printer, go through the User's Guide. Hope this helps.
Jul 12, 2010 | Lexmark X4270 All-In-One InkJet Printer
Can not add my fax machine ???
your connection for the printer is ok, is your phone jax connected correctly. from the wall to back of printer (in)....and from (out) printer to (phone line in) pc....did you download the brother's printer/fax software completly...when done the test page would print and say fax is ok or not....if ok this will allow you to configure the time/date and rings to answer (your fax # is your home #) note if you have an answering machine and it picks up on the 5th ring (you will be better off setting the fax to pick earlier then the 5th)
May 29, 2009 | Brother Office Equipment & Supplies
Brother IntelliFax-4100e Fax Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
