Question about Refrigerators
I have a Bauknecht KRIC2533 integrated fridge. The white rubber seal on the inside of the door has pslit and I need to replace it. Where can I get a new rubber seal from?
  • Anonymous Mar 28, 2014
    We are having problems with the deteriating condition of the seals. We are based in Mallorca Spain and cannot find a distributor for the door seels locally
Found a supplier
Posted on Jul 08, 2008
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The water line in my Kenmore side by side fridge broke in the door how do i remove the inside panel to replace the line??
It's a shot...but if I recall correctly the rubber seal thats between the door and the fridge can be peeled back or removed, and underneath are the screws that hold the inside panels on...
I would peel the seal back a little at a time until I actually locate a screw...then once located... I would feel more confident about the removal of the entire seal. Keep in mind the seal is much easier to remove than to replace...I used baby oil in some place to replace the seal...Good Luck!
Dec 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
My fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
Aug 11, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Build up of a lot of water in side the bottom of my fridge the goods are still being kept cool. Fridge is a bauknecht IRU 1433 EN 153 Service no. 01/7875 66
I have had this problem. Although I have not been able to pinpoint the exact reason, I suspect that it is due to an old door gasket that is not providing a good enough seal all around the door. In especially humid weather, moist air outside the refrigerator gets in and the moisture condenses, much like on a glass of ice water on a humid day. If it bothers you enough, I'd say replace the door gasket.
Jul 23, 2008 | Refrigerators
Sub-zero Refrigerator Door
song to me door gasket was not properly installed, We using electric steamers to make rubber softer and good sticking. Right after door seal was replaced. Also, it could be that: a bottom door hinge parts broken /little white plastic cams damaged/,or, fridge not leveled or too heavy load on door shelfs.
________________________________________________
http://www.subzerolosangeles.com
Jun 27, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
