Question about Dell Inspiron 1525 Notebook
Spilled coffee of left side of laptop after cleaned it up it won't power on, not lights, no noise nothing. power cord has green light, but no power in laptop
  • Dell Master
  • 6,771 Answers
The motherboard probably has been compromised, the only way to be sure is take it to a computer tech and have it checked out with a estimate.
Posted on Dec 29, 2010
Why my coffee machine not going to the green light mode ?
it might not be reading the code. Make sure the screen where the bar code reader is has been wiped clean.
Jul 25, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
Blow electric circuits
First, check all of the outlets on the circuit breaker that is being tripped to see what's plugged in. Look at the nameplate information for each piece of equipment, including the coffee maker and right down the Amps rating. Add up the amps. If it exceeds the breaker current rating, you will either have to unplug or turn off something else in order to run the coffee maker, or plug the coffee maker into an outlet on a different breaker.
If that is not the problem, you probably have a short circuit inside the coffee maker.or bad insulation on the power cord. Unplug and unload the coffee maker. Carefully inspect the power cord. If there are cracks or breaks (pay special attention to the plug and the point where the cord goes into the coffee maker), then replace the power cord. It's tempting to just tape over broken insulation, but if the insulation is deteriorating, it's not worth the risk.
If the cord appears to be OK, then remove the bottom cover plate and inspect the wiring for both heaters. If there are signs of arcing between connections or wires, clean it up and repair the wiring as needed (Note: carbon tracks burned into plastic are short-circuit paths. These have to be dug out like a dentist cleans out a cavity in a tooth. Epoxy is usually a good filler.). If there is contamination from a spill, clean it up thoroughly using a damp rag if necessary (do not immerse in water). Wipe everything dry, then wait a while to be sure it is dry. Reassemble and test. If there is a water tank leak into the electrical compartment, you will have to evaluate whether patching or replacing the part is feasible.
Jul 19, 2013 | Bloomfield 8571 Coffee Maker
Spilled coffee on the front left part of my laptop
Well most liquid damages are not under warranty, and can not be repaired so basically, your laptop is screwed. what you can try is to blow dry it
May 21, 2012 | Gateway M-7317u PC Notebook
Printer won't turn on.
Common problem with this particular Printer is a Bad Power Supply,needs to be replaced,its nothing related to the cleaning you did.
you have Order a new power supply Board,open the back cover of printer and Install it.
Feb 04, 2012 | HP DeskJet 1220c InkJet Printer
Power cord stops working when plugged in.
next time when someting spills on your laptop , mobile , desktop u bring rice and spill it on the device the rice will drink the liquid in minutes then remove the rice but i have no answers for wat abut this i think u should change your battery
Jan 03, 2010 | Dell Latitude D820 Notebook
Laptop not working no lights nothing
get a new power supply. Try E-Bay
May 25, 2009 | Computers & Internet
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
The far left icon is red and the temp light green. I have taken everything apart and cleaned it. Now nothing happens, at first it would make the usual noises and nothing would happen.
sounds like a microswitch is out.
needs to be brought in for service. No easy way around it.
there's 3+ microswitches per unit depending on the model. They go out, red light comes on, nothing works.
Machine will have to be taken apart and all of them looked at one by one.
Apr 21, 2008 | Saeco Magic De Luxe Espresso Machine
Dell Inspiron 1525 Notebook Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
