Sir, due to heavy voltage fluctuation , my ups and LCD monitor is blown. I HAVE REMOVED THE BACK PANEL OF THE LCD MONITOR. SOME OF THE CAPACITORS ARE BURNT.I WANT TO KNOW THE VALUE OF THE CAPACITORS .CAN YOU GIVE ME THE SERVICE MANUAL
  • 55 Answers
You should better give it authorized person because they can better take care of it and most of the LCD's parts are non serviceable so kindly do not be self mechanic thank you don't forget to give vote :-) by :- pranshu
Posted on Dec 29, 2010
I have a 27 in lcd from digital lifestyle p/n fa2b-26zd2 with the same problem the tv wont power on after we loss power in our house for 4days. what could be the problem any suggestions .. thanks
Do you see any indicator lights on the front at all? If not, it may have a dead power supply. It can be as simple as blown main AC fuse in the power supply module ( it should be close to where the power cord is plugged in). When the power comes back on, it will usually have high voltage spike/surge due to all big heavy loads that **** down the voltage and rise back up quickly, This one reason I unplug all my electronics when the house lost power. You probably notice that the lights in the house get dim and then get real bright when the power comes back on and settle back to normal a few seconds later.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Nov 02, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Voltage stabilizers required for 32 inch LCD tv
Please clarify by what you mean "voltage stabilizers".
Do you mean the power supply module?
Try EBAY, or www.shopjimmy.com
Basic troubleshooting guide here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Sony 32 KDL32BX320 32 LCD TV
Samsung DVD player Model P460D Capacitor across the rectifier diode got burst, Fuse blown off due to voltage fluctuation / over voltage. after replacing the fuse and removing the bursted capacitor the...
Only if the power supply has been restored back with the replacement of the capacitor and fuse can we proceed forward. If not you will need to check the SMPS unit to replace damaged components to restore the supply.
If supply seems correct, then check the +5 to the processor unit. In event of high voltage it is possible that the mother board is affected.
Jan 18, 2011 | Televison & Video
My Proview Technology 15' tft is fluctuating from last week...actually it is minor fluctuation..i tried to solve this problem by removing speakers form it's side but it doesnt effect this...
Magnet does not affect the LCD panel like the CRT monitor because LCD dose not use electron beams for display function.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 20, 2010 | Proview Technology 15" .297 1024x768...
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor shows lines and flickers
check for any magnetic fields if not check the power cable for any voltage fluctuation..or else you may need to change the monitor...
Mar 01, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My lcd tv truns off after 1to2hrs of play
Remove the mother board...similar to your home pc,
Locate the capacitors that had gone bad
take it to a television repair shop and had them replace those Capacitors (with a slight voltage increase).
IT will Start Working fine.
It happened because of Voltage fluctuation so beeter connect a Voltage Controlling device to your Polaroid LCD.
May 14, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
The monitor vibrates every now and then
Dear Sir this happens due to voltage fluctuations. Check the voltage of your outlet or else check with ups. If it continues even after replacing the UPS. You need to consult a technician.
Thanks & Regards
Nanda Kishore.
May 09, 2009 | Computers & Internet
F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Jan 03, 2008 | Neovo AG 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
