Question about GPX Karaoke Party Machine
How do you hook the i pod up to the machine, we cant seem to figure it out?
  • GPX Master
  • 5,603 Answers
You would have to get a 1/8 inch to dual RCA plug stereo SPLITTER cable and connect to the jacks on the back.
You will be disappointed however, as the unit will disable the microphones when you send music into the jacks... The thing just acts as a straight amplifier in this mode.
The only way to have a microphone active AND the IPOD is to sacrifice one microphone and use a mixer of the IPOD stereo output into a mono line into one of the microphone jacks. You can build your own mixer by using a couple 1K ohm resistors from each of the IPOD's output (stereo) leads into a single plug to plug into where one of the microphones plug in. You cannot tie the two leads from the IPOD together or each side of the stereo would fight the other causing distortion, hence the resistors prevent this.
Posted on Dec 29, 2010
Just bought the mixer and cant figure out how to get sound to the main speakers, i have the apms correctly hooked up and speakers also
Since you posted this question nearly 3 weeks ago, I expect you figured it out by now - in which case, please mark thread as "closed".
If you are still trying to figure it out, please reply with the following information:
1. Make and model of mixer
2. What you are using as a signal source (mic, instrument, etc.)
3. Make and model of your speakers (important if they are self-powered, or not)
We'll take it from there - but a couple pictures will answer a lot of questions in regard to gain structure, signal path routing, buss outs, etc.
May 21, 2016 | Music
Podhd400 not working
Try doing a reset as explained in this video-
http://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214
May 09, 2014 | Line 6 POD HD400 Pedal Multi-FX Guitar
There is no factory recall on my pod xt pro
That's correct, there is no onboard recall. In order to reset, follow the instructions in this link-
http://line6.com/support/page/kb/_/pod/pod-20-podxt-family-pocket-pod-floorpods/pod-xt-series-factory-reset-reflash-and-firm-r491
Apr 06, 2014 | Line 6 New Line 6 Pod Xt Podxt Live...
I need a operator manual for a lonestar sk-104 karaoke manchine
I have the same one. and I have had another model also.they are almost the same.If I am correct it is a cassette karaoke player.They take a special cassette that says lonestar super K.these players and tapes were from the 1992-1994.when you hook to the tv, the tv needs to be on channel 3 or 4.the back of the machine should have a switch with 3 &4.make sure both are on the same.on newer tv you may have to figure out the input & output.some say video some say line 1 line 2 etc.my machine uses a cable cord from tv to machine.any tape will play in them ,but only the special ones will put words on the tv. if you use the special tape when you put it in the machine only one side plays.it tells you on the tape.also only one side of the duel cassette compartment will put words on screen.my sk104 is side B.Hope this helps.if you still cant get on screen words,it could be that part of the machine just doesn't work anymore.that is what happened to my other one.
Dec 15, 2012 | Music
My mixer works but all the lights and the fxs went out
Hi, i wonder if you solved your problem, because i have exactly the same issue with my Numark 5000FX and i cant figure out how to solve it.
I would really appreciate any help.
Nov 02, 2012 | Numark Industries Numark 5000FX 5 Channel...
I was updating the flash memory of my Pod HD500 and than I turned it off when was updating proccess and now when I connect my HD500, it turns ON and OFF every 20 seconds. I dont know what to do, I cant use...
You have one chance to save this and that is to attempt to flash it again... Flashing is disastrous if power is killed before the flash is complete. You had better hope that the flash boot is still OK so you can redo it from scratch, else it is likely you will have to take it to a service center where they MAY have equipment to re-burn the flash by a direct connection.
Jan 14, 2011 | Line 6 POD HD500 Amp Modeler and Multi...
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Cant hook up my casio 2000ctk 2 computer
if its a midi keyboard, it should be in your audio settings in control panel under the midi device, ive used fl studio with these before, or reason. hope this helps in some way.
Nov 30, 2009 | Casio CTK810 61 Key Keyboard
GPX Karaoke Party Machine Logo
193 people viewed this question
Top GPX Music Experts
Vito Vacirca Jr.
Are you a GPX Music Expert? Answer questions, earn points and help others
