Question about Heath Zenith SL-6106-IV Motion Sensing 180° Wall Sensor, Ivory
Looking for a wall motion switch that has a 180 degree side view
    Problem Solver:
  • 5 Answers
Try the GE Motion sensing switch found at Wal-Mart on the electrical asile. I believe it is made by JASCO Products. I use this is my garage and closets without an problems.
Cheers,
GeekyGuru
Posted on Dec 30, 2010
Defiant flood light 180 degree led: 1. Instruction manual says to put a maximum of one such light on a wall switch. Why can I not have 2? 2.it has photo sensor in addition to a motion sensor? Thx.
Maybe two light fixtures each with photo sensors and the lights being near each other, might trigger both sensors to react to each other and turn lights on and off rapidly.
Jul 09, 2016 | Home Security
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Motion light detection wiring
Black wire to constant power
Blue wire to load (to your light)
Green wire to Ground
Feb 20, 2014 | Leviton R01-PR180-1LI Decora 180 Degree...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
I installed the PR180 switch in my garage with a 4ft dual t-8 flourescents bulbs. When the motion sensor timer turns the light off the flourescent bulbs stay slightly lit, as if it were on a dimmer...
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
Nov 28, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Display on the screen/monitor
im not sure if this will help but if your video card have its own control panel try going there and try looking for Rotate Display or something close to it. Im using Nvidia 6200LE and it has the option to rotate 90 and 180 degrees..you might want to try it
Nov 28, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Heath Zenith SL-6106-IV Motion Sensing 180° Wall Sensor, Ivory Logo
Top Heath Zenith Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Heath Zenith Hardware and Accessory Expert? Answer questions, earn points and help others
