Question about Orion1934 19" TV
Many channels do not come in. I feel it needs reprograming. I have cable .
I have a previously owned Tv . Orion 1934. The universal remote is making connection but many chanels have to be put in and many do not come on. A channel that is #76 comes in at 25.
  • 4,234 Answers
Make sure that the set is in the correct mode. It sounds like the set is expecting TV signals from an antenna rather than cable. The cable channel assignments are different. Place the set into CABLE mode and autoprogram the set. That should resolve the problem.
Dan
Posted on Jul 07, 2008
Need code to reprogram phillips universial sru2103s/27 remote to an Orion TV
Apparently, the S series autoprograms.
Hold the setup button until the remote's light stays on. Then, quickly press and release the TV button and it should blink off once. After that, just press the up channel button (CH +) until it changes channels.
Jun 08, 2010 | Philips Universal PH301S Remote Control
Remote no longer works-need code to reprogram it
the only codes i have are 0121 0135 or 0035
Mar 23, 2009 | Orion1934 19" TV
Can not get orion 1934 to response to no remote
First, there is no such thing as a 'universal remote.' There are only multibrand remotes that cover some percentage of the thousands of different brands and IR systems used over the decades.
If your set cannot be turned on manually, the set is sick.
If you know that the set is functional, you can buy an original remote here:
Remotes
Someone should bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Feb 11, 2009 | Orion1934 19" TV
We have an orion model 1934 tv and can only pick up a few channels on it-less than 12 and it is hooked to our cable which has 70 channels access. this is a 2002 year make so i think it should pick up a lot...
If you can, go into the ch set menu and change it from tv to catv(cable). then run the auto ch memory. I hope this helps. Orion's free help line is 800 289 0980.
Dec 17, 2008 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Orion model 1929
Hiii...
Mightbe you can buy a universal remote on the market what support your tv set ?
Than's
[Vrya]
Jan 16, 2008 | Orion1934 19" TV
Orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Nov 03, 2007 | Orion1934 19" TV
Program universal remote
check remote first, and replace ir ditector in the tv...
Sep 28, 2007 | Orion1934 19" TV
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
75 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
