There can be a couple of reasons that the CD player is skipping.
One is that the disk has fingerprints or dirt on it. (Carefully clean it)
Two, the lens of the player is dirty. (Try a CD lens cleaner)
If neither solution works, your CD player has given up the goods and requires replacement.
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
I think there are some disks with MP3 or other sorts of audiofiles.
If the radio does not support these it wil skip it.
If you set it random, the system will search for files it can play.
Either the disk is dirty or the laser lens is. Buy a DVD lens cleaner and use on your player. For the disks, carefully wipe it with lint-free cloth or toilet tissue. Be careful not to scratch the disk. All you are really trying to do is wipe off any fingerprints or lint/dirt.
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again.
If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
