Question about InFocus ScreenPlay 5700 Multimedia Projector
Lamp won't stay lit
On our InFocus ScreenPlay 5700, it turns on, warm up and displays the InFocus screen for about 1 second. Then, the lamp turns off. It seems to cycle if you leave it on. If you let it sit after the lamp goes out, everything starts up again and the lamp turns back on, but then turns itself back off about 1 minute later. Any ideas?
I've got the same problem, I'm wondering if it has to do with some sort of auto shut off kicking in due to overheating or something, I was gonna try replacing the fan to see if it's something to do with that
Posted on Jul 14, 2008
Blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
Aug 03, 2011 | InFocus ScreenPlay 5700 Multimedia...
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
5700 picture is black
if you know the lamp is lit, you can try reflashing the firmware. If that doesn't work then the main board and /or the engine is bad.
Jun 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
Bulb is working fine, how do i get rid of replace lamp on the screen?
go into the menu and select settings. in there there should be an option for lamp hour (or timer) reset. select and chose yes.
Oct 17, 2009 | InFocus ScreenPlay 5700 Multimedia...
Infocus 5700 new lamp unit makes variable blowing noise
it will speed up to increase the air flow if the temperature goes up, and slow down when it drops. it's normal. that's how it maintains a good temp.
Jan 19, 2009 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
354 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
