Question about T-Mobile My Touch Cell Phone
Sd card said it is unmounted and read only. How can I fix it?
    President:
  • 1,812 Answers
Just format it to any PC laptop /desktop in fat32 .Install the SD card ,switch off the mobile and switch on .
Hope it will solve your problem.
REGARD'S
Posted on Dec 29, 2010
  • Bsp Pc
    Bsp Pc Jan 08, 2015
    the memory can not format it's damage and i take new one still not respond. after fomarted fat32 yes it's worded thank u
3 Suggested Answers
  • 17 Answers
SOURCE: phone keeps asking to insert the sd card when its
Try master reset and format SD card FROM A COMPUTER if still not working its defective and needs to be replaced.
source: Someone who works for TECH SUPPORT with certain company in USA... Pink colors, nice girl in ads, you know.
Posted on Sep 22, 2011
  • 6 Answers
SOURCE: sd card, or device error when copying music files
If you are trying to play the file then it will be unmounted as it needs to disconnect from the pc to do that you could try copying them in batches if that doesnt work it may be a USB driver fault in which case i would reccomend reinstalling the G1 driver.
Posted on Jul 07, 2009
My device is not a cellphone. Its an android but i followed some of your directions.
unmounting allows for safe removal of the sd card from device,meaning when you unmount the device doesn't read the sd card anymore until you remove it and insert again...erase basically formats the sd card
Nov 26, 2015 | Android Cell Phones
My phone says SD card is unmounted when its mounted. I have tried another SD card and it still says its unmounted what can I do to fix it. My phone is a Kyrocera.
is your card accessible? Im betting its a bent pin in the card slot. You may be able to use a dental pick (very thin strong metal pick) to gently pull the pins down ever so slightly to make contact with the card again. Sometimes gluing a tiny piece of foil over the card contact helps reach the bent card contact but thats assuming your phone is unrepairable and you dont have the money for a new one.
Aug 18, 2015 | Cell Phones
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
How do l mount a sd card on my zeki tablet TBDG734B
Mounting is done automatically by the device in most
Android tablets.
For an Android, all you have to do is insert the SD card in the slot and it will be mounted automatically. If you want to remove the card, though, you need to *unmount* it. You can unmount in Settings>Storage>External SD card and will see the unmount option listed below it. Touch it and then you can remove your SD card without the possibility of corrupting the files.
Apr 17, 2015 | Tablets & eReaders
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
Camera says sd card unmounted wont work was working fine last night
In the settings menu under storage there is an option unmount sd card every time before removing the card from the phone or tab you should press this option unmount sd card otherwise directly removing the card without sectiong the option causes these errors
Oct 21, 2013 | T-Mobile Cell Phones
My Kyocera Rise has LOTS of problems! The one I want to ask is why do I keep getting a random message saying, "SD card has been unexpectedly removed"?
There are several possible reasons for this. The Kyocera Rise requires an SD card to be unmounted through the memory option in the settings. If you remove the SD without unmounting, you will receive the error message. The Rise also has several software issues that sometimes cause your SD to stop being read, even while still inserted. If you receive this error message without removing your SD card, it is recommended that you take your phone to a company certified Sprint store to have it checked out.
Jul 01, 2013 | Cell Phones
My Pantech sd card reader is not working
I don't know what machine you are using or the SD device GBs. Older machines sometimes do not read any SD over 2GBs. That said, there may be updated drivers for your machine and devices. Could be the file format isn't compatible. Hard to say with little info to work from.
Nov 17, 2012 | Computers & Internet
Am uzing lg p970 (red bull). i want to unmount my sd card because the gudget says sd card removed despite that i had inserted one
insert another sd card if the problem persists u take it to a hard ware repairer close to u
Oct 18, 2012 | LG Cell Phones
My sd card is saying blank and unsupported
Is your computer able to read the card with an SD adapter? If so, back up any information on it to the computer. Put card back in phone and go to settings->storage->unmount SD card->then format SD card. Allowing the phone to format the card usually has better results than formatting it in Windows because it's going to use the correct file system type.
Hope this helps
Ray
Mar 02, 2011 | HTC G1
T-Mobile My Touch Cell Phone Logo
228 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
