Question about Frigidaire GLWS1339AS Top-Load Washer
Leaking from some where-hoses are dry - Frigidaire GLWS1339AS Top-Load Washer
  • 1,557 Answers
The way we fix this is put a small amount of water color / red /blue into the bowl take the back of and watch as it washes to see were the leak is
Posted on Dec 29, 2010
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Could it the water pump
Coolant leaks can be difficult to trace because the leak can migrate away from the source. To start with, dry off all areas that are wet. Then ,with a flash light, inspect the hose and water pump to see where the leak originates. This is done with the engine running so be mindful of all moving parts as you look through the engine compartment. It may be the hose that is leaking.
Apr 21, 2014 | 2002 GMC Yukon XL
Coolant leaking on the right side
Joel's suggestion is really good, but i just wanted to add one thing. If you have a couple extra bucks loose, you can also go to your local parts store and ask for a UV dye tracer kit to put into the coolant. If you get one of those, you just need to pour a bit in with the coolant and run the car a day or 2, then use the UV light to trace the leak. But cleaning and drying the engine off, running it a bit and looking for the leak will do a good job for free, but it's sometimes a bit harder to really trace the leak if the weather is bad and stuff like that.
Apr 06, 2014 | 1992 Honda Accord
Washer works but there is a leak and hose connections are dry.
Look under the washer and see if the leak comes from a faulty drain valve/pump or from a loose hose clamp. If so remove clean - back-flush or tighten the hose clamp.
it is possible that the drain valve is clogged as you mentioned the hose to be dry and so the water seems to collect here and leak.
Apr 01, 2011 | Washing Machines
Water leaking to the floor
check the hose connections to make sure that they are tight. then check other hose connections. after you find where the water is leaking, tighten the hose clamps (usually need a screwdriver) and make sure that the hose is not cracked, ripped or dried up and brittle.
Aug 14, 2009 | Whirlpool Washing Machines
Antifeeze leak on my 2000 VW Beetle Turbo
Most likely a leaky gasket. The water pump is a likely candidate, but also could be from a bad radiator hose/thermostat connection. Would suggest washing down the engine with a hose connected to the hot water. While the engine is cold use the hose to wash off the oil & grease deposits and old antifreeze. Allow the engine to dry without running the car. Once dry start the car and be prepared to look for the first sign of a leak. Sounds like a dealer issue since there is very little work clearence between the front of the engine and the car body. Barely enough room to be able to change the serpentine belt.
Mar 20, 2009 | 1988 Buick Regal
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Water leaking from bottom. what's up?
the best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Jan 16, 2008 | Starbucks Saeco Italia Digital Barista...
Frigidaire GLWS1339AS Top-Load Washer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
