Question about Refrigerators
I removed the bottom drawer of our Maytag model MFI2569VEB2 to clean. How to I get it back in?
sdmc73
  • 121 Answers
SOURCE: moving refrigerator
give it one hour at room temp
Posted on Nov 29, 2008
SOURCE: maytag refrigerators mtbe1956de
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Posted on Jan 13, 2010
Testimonial: "Gee... you are really smart! When id doubt brute force is good."
SOURCE: Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Posted on Jan 20, 2010
aviral_srms
  • 1216 Answers
SOURCE: I have a Maytag model
As per your explaitions i can say that you had your gagket not fitted well so if you cannot do it yourself it requires someone with more experience than you.If you are sure that gasket is perfectly fitted proceed next.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Apr 03, 2011
imufo2
  • 3773 Answers
SOURCE: We have a Maytag Peforma Model PBB2255GES Maytag
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 31, 2011
I was following a question from previous person. I have ice that builds up and leaks out of my Maytag freezer drawer. MFI2665XEM7 french door with ice maker on door NOT in bottom freezer drawer. I...
No need to remove panels, when you can see where the hole is (or should be. Sometimes it is hidden behind some algae. Us a straw or something like that to clean it.
Feb 16, 2015 | Maytag Refrigerators
How do i remove drawers from bottom of maytag refrigerator model mff2258vew2
http://www.searspartsdirect.com/partsdirect/user-manuals/2155/MFF2258VEW2-Maytag-Parts-REFRIGERATOR-manual
Open this site and go to page 10, it has detailed instructions on removing the bottom drawer.
Jan 21, 2013 | Refrigerators
How do i remove the drawers from maytag model mff2258vew2
Open this link to this manual and go to page 10 for detailed instructions on removing the bottom drawer.
Jan 21, 2013 | Maytag Refrigerators
Location of the spark module on a Maytag range/oven model MGS5770ADC
Most time it is on the back side under a shield
Move a shield and you will find it
This stove has these sealed burners:
Give em a twist and lift these puppys out like this:
If it ain't on the back then remove the bottom drawer and it will be under a shield in there.
Hard to tell on the diagram
Sep 20, 2011 | Maytag MGS5770 Gas Kitchen Range
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Where is the model number/ serial number located on the Maytag Gemini?
    Open the door and look at the very bottom, front of range. If yours have a drawer it will be located behind the drawer right under the bake door, on the oven frame.
    Jan 05, 2010 | Maytag Gemini 30" Self-Cleaning...
    Maytag oven: How to clean
    Before you self clean you always want to take a rag with warm water and remove all chunks of food.
    Next clean around the frame of the door gasket with the rag(these cant get clean in self clean) do not clean gasket IMPORTANT
    Remove all racks and pans
    Most older door handle locks require a few buttons, get your model number(which is located either on the frame your bottom drawer shuts on if a single oven, if double is on door frame if built into cabinet walls, if on floor its on back of control panel, a piece of metal thats like a mailbox flag, you turn it to read model from front) and go to www.maytag.com click support then manuals enter your whole model number EXCEPT the last letter. (example if your model is MER6775AWW enter MER6775AW<--only one W) This should bring up use and care guide, which will give step by step instructions, if you follow them and it wont clean, your latch most likely needs replacement
    May 02, 2008 | Kitchen Ranges
    Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug....
    remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
    Mar 08, 2008 | Kitchen Ranges
    Maytag Frenchdoor w/freezer drawer - drawer sticks
    you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
    Jan 23, 2008 | Maytag MFD2560HES Bottom Freezer French...
    Refrigerators Logo
    80 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
