Question about Mitsubishi VS-60607 TV
Lines across the screen
I have lines on my screen . it starts out with 1 or 2 and then gets worse after it warms up. my set is 8 years old . is it worth fixing or is it going to cost more than its worth?
  • Anonymous Jul 18, 2008
    my screen has lines across it and get worse as it warms up i tried to adjust the crts and didnt work just made it worse what should i do???????????????
We just picked upi a VS-60607 60 inch projectoin tv,  There are several issues with this television.  when powered on the colors are allconstrued and teh image is often chopped and warped, we hooked upi the cable yet there are only two local channels recieved and the power will turn off randomly every severl minutes.   Any thooughts?
Posted on Sep 26, 2008
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
My TV is less than a year old. It has white
Do these lines disappear after the set warms up a little? If they don't then you most likely have bad buffer boards(X buffer or Y buffer). Sometimes it is also caused by a bad panel. Since your tv is less than 1 year old and is still under the 1year manufacturer warranty I strongly suggest that you contact the manufacturer for repairs.
Contact info:
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Please rate this solution if you found the information helpful.
Thanks,
Sai.
Mar 29, 2010 | Sanyo DP50747 50 in. Plasma TV
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Horizontal line across screen
take it to a tech.because the diagonstic is dangerious and it won't be a simple job.could be everything & anything electronic.
Nov 29, 2008 | Olevia LT42HVi 42 in. LCD Television
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Mitsubishi VS-60607 TV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
