Question about Kenwood Audio Players & Recorders
I have a kenwood MIDI M-45 /MIDI M-757 audio system. The CD player won't play. The disc loads but error comes up NO DISC, can you help????
  • Kenwood Master
  • 6,771 Answers
The cd unit is not reading the disc, the laser pickup may be dirty, or the pladder motor that cd sits on may be defective. If you can get at the laser pickup lens, clean it with rubbing alcohol with a Q-Tip very carefully in circular motion and allow several minutes to dry.
Posted on Dec 29, 2010
Testimonial: "Thanks for the quick reply and fix it solution. Will try it."
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
Toshiba SD-3980 DVD player not working
check and clean dvd lens. change lens if same problem.
Jun 02, 2009 | Kenwood XD-A55 CD Shelf System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Kenwood KDC-C662 6-Disc CD Changer - Error 'T99'
Hi....
Just accumulated dust can cause issues with the reader pickup
I'm not sure what T99 means but if you want to spend $35-90 to fix it,
it would be worth it.
Jan 06, 2009 | Kenwood KDC-C662 6-Disc CD Changer
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
Error 5
Your CD player thinks the CD is in Upside down. Basically it cannot read the disc. You need to run a CD laser Lens cleaner disc to hopefully get it back reading the Discs good again. Otherwise you will nee to take it apart and clean it all yourself manually.
Nov 04, 2007 | Kenwood KDC-MP628 CD Player
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
TOC Error
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Dec 07, 2006 | Kenwood KDC-M7024 CD Player
458 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
