I have a hitachi 51F710s when sitched on by remote it will blink 2x then shuts off. i tried unplugging it for 2 hrs. it worked for a while then the same problem occured. what could be the problem?
  • rnbjames6 Dec 30, 2010
    thanks for the info, maybe i need a diagram, and which part to replace and solder. i am ok with soldering no problem with that. right now it does not turn on by remote and manual. if you can give additional details that would be helpful. thanks again.
  • rnbjames6 Jan 07, 2011
    ok just got your message thanks again and will dwnload the manual and will contact you again once i have it.
  • 4,889 Answers
The cause of the problem seems to be an overloaded circuit on the power supply. We should look for faulty electrolytic caps on the power supply and replace any faulty ones Which begs the question, how good are your electronics/soldering skills?
Posted on Dec 29, 2010
I have a Sylvania TV with dvd/vhs attached and do not have the remote. I can't get the tv on channel 3 to watch cable. I have tried numerous universal remotes but none of them have worked. Please tell me...
Here is a process to program a Vizio Universal remote. I saved this info to my computer as a text file some time ago. Can't remember where from, so if it works, no credit to me. :-)
Sylvania:10054, 10030, 10171, 11944, 11931
1. Manually turn on the TV.
2. Press and release the TV button.
3. Press and hold the SET button until the LED blinks 2X.
4. Enter your Codes
If the code is accepted, the LED flashes twice after the last digit is entered.
If the LED does not flash twice, repeat Steps 2 through 4 with the next code listed.
5. Point the remote control at the TV and press the POWER button. The TV will turn off.
Vizio Remote Reset
(Use this step if the LED doesn't blink twice after entering the above codes)
1. Press and release the TV button.
2. Press and hold the SET button until the LED blinks 2X.
3. Type 9-8-2, the LED should blink 4X.
4. Now follow the steps above for Programming the TV again.
Jul 07, 2014 | Televison & Video
Someone cut off the power cord for my Hitachi 51f710s and not certain where the power supply is
That one I am fairly sure had a plug on cord---look where opening for cord is and inside for two metal pins in a socket---rectangular with white plastic.
Apr 19, 2012 | Hitachi 57F710 TV
How can I program my Comcast remote (Silver body - Red OK button) to work with my Hitachi CMP4201U monitor. I tried the 5 digit codes in the Comcast manual, but they don't work.
Here are the 9 codes that could match your universal remote to your Hitachi televisions;
10145, 11145, 10151, 11960, 10679, 10165, 10386, 11993, 10842
if these codes do not work you can search for your code by following your instruction manual.
here are the instructions to do a code search if for some reason they are missing from your manual.
Searching For Your Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TV key will blink twice.
Jul 02, 2011 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
My tv looks fine than sometime it will just shut off, and I will have to wait to turn it back on and it my stay on for 2 day and not shut off
Samsung HL-R6167w standby light blink do not power up sometime it would come on and work then it shut down the fan spin with a noise when press remote the green power light flashes.
Jul 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
TV turns on for 2 second and then it is off
Your TV may have detected an error. Try first to have the TV unplugged overnight just to clear it out then observe it after turning it back on.
Jul 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Tv will work for 10min. or hrs. then cuts off kv-36hs500
it blinked 6x. I unpluged the tv for 12 hrs. and it is fine. trouble shooting said it was horizontal hold overload.
Dec 10, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Jun 14, 2007 | Hitachi 50EX20B 50" Rear Projection...
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
