Question about Sylvania G-Netbook
Gdent44@enturylink.net I cannot get my netbook connected to the internet
  • 600 Answers
If your trying to get on the internet with a wireless connection.and running WINDOWS, (many problems with LINUX).and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 29, 2010
Just got netbook and it does not connect to the internet- what can be done to correct this so it works properly?
does it have wifi built in? do u require a dongle to connect to the net? have you tried connecting to your router with a lan cable to test things?
May 05, 2011 | Sylvania G-Netbook
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
I recently purchased a wireless mobile netbook. I already have internet servide but I don't have a wireless modem. How can I hook up to my present internet service. Thanks in advanced. Rebecca
You need to connect your net book via a cable. The cable is called a cat5 cable and looks like a big phone jack connector. It is just like the one that hooks your computer to your wired network. The cable can be hooked to one of the outlets on your wired network. Then your netbook should detect your connection and hook up.
Feb 14, 2011 | Sylvania G-Netbook
Cannot connect to internet explorer. replies PPPo. concentracter not here. net book does not connect to internet. worked at christmas now it says page cannot be displayed. model# synet7wid
PPPo is generally a setting on DSL modems, not on a computer. Can you verify that your modem is working correctly? Is any other computer in your house able to connect to the internet? If you ISP (internet service provider) modem has lost it's settings, your internet connection would not be available, thus the message your are getting on your netbook.
Please let me know if your internet connection is available for other computers and what kind of internet service you have.
I will watch for your reply.
Brian
Jan 23, 2011 | Sylvania G-Netbook
My dell net book has been stolen how do i tract it
When the robber connects to Internet, your MAC address gets visible to the internet provider your netbook is connected to. Your netbook's MAC address is unique, so the police could find it, if you prove that this is your gadget! good luck
Jan 19, 2011 | Samsung NC10-14GW Notebook
How do i get my netbook to connect to the internet/ what wireless device can I get to make it work
You need to have an active internet connection with a wireless gateway to connect to the "net" wirelessly. You also need to have a wireless device installed in your laptop. The device in your laptop usually has a switch to turn it off and on. This switch maybe on the side of the laptop or may be on one of the keyboard function keys, either way, the wireless support lamp should be on or green for the wireless system to work on the laptop.
If you do not have an active wireless internet connection, you cannot connect to the net although you should be able to connect to a unsecured wireless network which is in range of your laptop ( like in a shopping centre).
If your laptop does not have a wireless device fitted, visit your local computer shop to ask what they have available and at what cost.
Jan 14, 2011 | Sylvania G-Netbook
Trying to get my sylvania 7 inch netbook to bring up the internet, but it keeps saying to verify the baud rate settings
I used a router and adjusted the same conf. for both the router and the net book. All you need to do is to match both. I also know that you need to activate the wi fi by pressing the fn f9 buttons at the sometime. Try to log on and if it says connected but you are not able to use the net go to internet options and type yahoo.com or goggle.com. If you still not able to connect shut down and log on again. It works. Hope this helps Mrs.Mo
Sep 08, 2010 | Sylvania G-Netbook
When one computer is on the internet, the other
Yes You have to buy a minimum of a 4 port router wireless is best.
Oct 15, 2009 | D-Link DIR-615 Wireless Router
Sylvania G-Netbook Logo
23 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
