Question about HP Compaq WF1907 Monitor
Monitor what does OSD LOCKOUT ME
    President:
  • 173 Answers
The OSD (on screen display) is a lock feature that locks out all access to the control functions. Basically you can use this feature to lock the access to the control functions once you have everything set the way you want it so no one will be able to adjust them without unlocking it. To learn more about this option you can review this lcd monitor manual to learn about the details that your monitor might have (this may or may not be a manual for your specific monitor, but I am using it so you will get an idea about the different features some monitors might have. Yours may or may not have all these features). I hope this helps answer your question. If you need further assistance, I will be more than happy to answer any of your questions or help you. Have a good day.
If you would please rate my help, I really would appreciate it. Thanks
Posted on Jul 08, 2008
  • 4 Answers
Hello everybody,
I know how to fix this, but it involves opening up the monitor....
First unplug the monitor and get all the cables out. Then get the monitor of its monitor stand, this is done by unscrewing the four screws at the back of the monitor stand.
Now you can pry open the case with a flat screwdriver. On the inside you see a small electronic board with the power switch and the other switches on it. These 'broken' or dirty switches are what causing the OSD lockout.
Get the small board out of it's bracket and use some ETHANOL or ALCOHOL (atleast 70% pure) to clean the switches, you just spray or drip the ethanol into/onto the switches. This will clean the switches of any grease residu. Then spray the switches with air out of an airspray can untill they are totally dry.
Now you can put everything together and voila! it is working again!! atleast it worked for me :):)
This fix will only work if the switches aren't broken but only dirty or a little bit stuck, if they are broken then you would have to solder new ones on the electronic switch board.
Good Luck!
Ralph S.
Posted on Dec 23, 2008
5 Suggested Answers
  • 905 Answers
SOURCE: HP pavilion vf15 monitor (OSD lockout)
this could be a bad button connection or the osd IC chip is failing for some reason that would need to be tested to determine why.
so if you can take it apart then clean the button and the plastic of dirt , and check the contact button to see if it looks faulty or check it to see if it is making contact all the time
if those are not the problem then it is the IC chip and will need testing to find the culprit
electech
Posted on Nov 22, 2008
SOURCE: osd lockout
hold the MENU button for ten seconds to unlock or lock the OSD
Posted on Aug 19, 2008
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
SOURCE: How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Posted on Jan 20, 2010
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
How the unlock osd
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
HP Compaq WF1907 Monitor Logo
284 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
