Question about HP Photosmart C6180 All-In-One InkJet Printer
I unplugged the printer and plugged it back in now it won't start up. It will act like it is trying, the small screen on the left side shows the unit has power to it but the printer doesn't go thru its start up sequence. Any suggestions?
It won't turn on
Verify the power supply unit fuses.
Feb 21, 2013 | Canon PIXMA MX330 Multifunction InkJet...
Hp officejet 9120 won't power down but won't print either, it seems to be locked up, display just shows dots scrolling right to left
Unplug your printer from the outlet for several minutes and repower it back up. I have had this with my printer and usually solves the problem.
Jan 02, 2012 | HP OfficeJet 9120 All-In-One InkJet...
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Carrage jam
1) Open door so print heads move to the center
2) Unplug the unit. (Don't turn off, just unplug!)
3) Open back door
4) Look inside the back left side for a small black gear (About the size of a quarter)
5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
6) Keep spinning the gear until the plate moves all the way forward.
7) Grab the plate and try moving it forward more.
8) Put the back on and close the top.
9) Turn the unit back on.
10) Open the top again
11) Unplug the unit again. (Don't turn off, just unplug!)
12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
13) Make sure that the print heads slide left to right smoothly
14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
Ref - http://www.fixyourownprinter.com/forums/inkjet/22798
May 07, 2011 | HP Officejet 7210 All-In-One InkJet...
My HP Photosmart Premium C310 will not turn on. The computer said it was "offline". I've read the other forums and tried their solutions but none have worked. There is power to the printer....
Hi..
I will suggest you try reset the printer, follow the instruction below to reset your printer, if the problem still persist, replace the cable that connects the printer to the power outlet. If that did not still fix the problem,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
May 05, 2011 | Office Equipment & Supplies
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
What does c-7 980 mean
It means your waste toner is full. Pull the process unit and look on the each end for a screw on each side that are recessed. Remove them and take out the small panel that acts as a plug. Empty the excess toner out of each side and put covers back on. Then put your process unit back in go into the service mode. Press stop/clear button hold down, while holding press start button keep holding both buttons and then press the left side exposure button..hold all 3 buttons for approx 20 seconds till U comes up and starts flashing. Use the buttons under the display and put in 100 and press start to reinitialize the developer. After the unit stops initializing turn it off and on and you should be all set.
Nov 12, 2009 | Copystar CS-1500 Copier
TRYING TO CHANGE THE DRUM AND NOT SURE HOW TO GET IT OUT.
Open the top door
remove the toner cartridge
unplug the DV unit plug on left side
move spring loaded gray lever to the rear and hold
grasp the vertical part of the DV unit , lift up and out
open left door
remove the waste bottle
push small gray button on drum and pull drum out
remove tape on new drum carefully
reverse procedure to install.
Jun 27, 2009 | Kyocera FS-3830N Laser Printer
C7980 error code
Apr 03, 2009 | Copystar CS-1500 Copier
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
