Question about Canon Pixma iX5000 InkJet Plotter Printer
How to solve problem with my Canon iX5000 error code 5C00 ?
  • Canon Master
  • 4,338 Answers
This error code is telling you that the purge unit did not complete a good power on cycle and the cam is not in the correct position. Typically this means the purge unit is stuck extended due to accumulation of a lot of dried up ink.
Open the cover and when the head comes to the center, pull the power cord. Once that power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads and press them down. If the Wiper blade is extended, clean it and it should snap back in position. If it is still stuck, try spraying the area with Windex but don't get any on anything except the pads.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 29, 2010
Canon ix4000 error 5c00
Posted on Jan 09, 2011
Canon IX4000 Error 5c00
Error code 5C00 means purge unit is broken, yo have to replace the purge.
Mar 11, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
When i turn the printer on it tells me error code 5c00
Hi andrew_webb0,
The error code 5C00 means the purge unit is broken. To fix this, you have to bring the printer to a Canon service center and need to replace it with new one.
Hope this helps.
Feb 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Error code 5C00 means purge unit is broken. You need to bring the printer to the service center to get broken purge unit replace. I hope this short information help you. Thanks.
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
5c00 error code
A 5c00 error relates to the sensor in the purge unit, which is where the carriage stops on the right hand side of the printer. You may find that the ink has built up in the purge unit and it will need to be washed out in warm water. The sensor in the purge unit will need to be removed before washing the unit.
Fixing this error is much easier than it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad as my error occured after a paper jam.
To reset canon i80 after fixing ink overflow, i was able to follow this reset. i90 i believe is the same.
Try the following procedure:
1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time.
2)Release the Resume/Cancel button. (continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons.
4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green.
Power it off and back on and you should be good to go!
Good luck :)
Oct 22, 2009 | Canon Pixma iX5000 InkJet Plotter Printer
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Oct 14, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Error Code 5c00 for Canon ix4000
5C00 is a purge assembly error, it happens when paper is caught stopping the cleaning blades from working properly, or when the purge unit is just worn out.
Aug 20, 2009 | Office Equipment & Supplies
Error code 5C00, Canon Selphy DS810
HI..
It means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it...
thank u
rate me
Jul 25, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon Pixma iX5000 InkJet Plotter Printer Logo
2,001 people viewed this question
old marine
old marine
