Question about HP Photosmart C5280 Printer
Small brush I have a small brush that came loose with a check that I printed this morning. Where does it belong? Can I put it back in place? It still has a sticky back to it. Judy
  • 3 more comments
  • Anonymous Jul 08, 2008
    I have the same problem...
  • nadinedunn53 Aug 16, 2008
    me too!! anyone have any ideas??
  • lizbit4 Oct 08, 2008
    Same problem here. Printed an envelope and the brush came out. It definitely must serve some sort of cleaning purpose. Cleans ink off of some electric eye maybe? I looked underneath my black ink cartridge today and can see a TON of excess ink...hmmm
  • anelson Jan 01, 2009
    I have the same problem, printed something on regular paper, paper jammed and when I opened the printer to clear the jam, the brush was stuck to the wadded up paper. Hopefully printer will work without it for a long time as we've only had this printer about 6 months and only replaced the black ink once.
  • zobb Jan 05, 2009
    found loose self adhesive small brush running in printer; does anyone know where this came loose from?
Same problem, no solution. Sorry. Brush with sticky backside came out with paper after running a copy of a document (more grinding and noise than usual). POS HP. I used an Epson color inkjet for 12 years with no problems other than eventual aging and jet clogging/print degradation. Bought the HP, thinking what the heck... good for everyone else. Right? Wrong. Have had it about six months, VERY LIGHT printing, and it loses some random brush when I decide to put it into copy mode? Brush is like a miniature straight broom, adhesive on the back. Black or grey on the ends due to whatever its job has been. Now I fully expect my prints to be a mess in about three months or so, thereby making the printer worthless... a paperweight at best, as the brush is no longer there to do whatever it was supposed to do. If it goes to HIAB then HP customer satisfaction and Better Business Bureau will hear from me.
Posted on Aug 27, 2008
Trying to put starter back together using same bushings but can't get them to stay in place so I can put them over the shaft. Please Help!
Mark, It can be tricky, use small ***** driver to push back brushes one at a time while working armature in place or if you can get a buddy to hold them both back while you slide armature in place.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to rebuild Briggs and Stratton starter motor replacing bottom end cap...
How to rebuild starter small engine
STARTER REBUILD on KOHLER KT 17HP Bobcat UTV Engine wmv
brush installation AVI
Apr 02, 2016 | Kohler Command PRO OHV V-Twin Vertical...
My asian forest scorpion got loose what should I do
What else - find him, catch him, and put him back where he belongs. Good luck though. They're fast, and hide in small, dark places.
Oct 11, 2015 | Cars & Trucks
I took the bottom plate off to clean brush - cleaned it and put it back on and now the machine is making high loud noise - overheating and the hepa filter turned black.
HI, it's Jim from Crucial Vacuum!
The first thing I would check is to make sure the vacuums belt is attached to the brush roll. This may have been dislodged when you initially took off brush roll.
The other thing to check for is to make sure the brush roll itself has been attached properly. Also, check to see if all of the screws to take off the plate have been put back properly and that one of them hasn't been accidentally lodged into your vacuum.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Jan 13, 2015 | Filter Vacuums
Location of brushes on dremel multi max kit
There should be a second brush. Look along the motor - you're looking for a spot where the armature (the part that rotates) is surrounded by a ring of little straight copper-colored bars. That's the "commutator" section. The brushes run against the copper bars.
Look on the outside of the plastic shell - there may be two large plastic screws, one on the outside of each shell half, right about where the commutator would be on the inside. Those are your brush holder screws; you should be able to change the brushes from OUTSIDE the tool without opening it. Some tools are built without external brush holders like that, but most have external brush holders.
If you find external brush holder screws, then track down the second brush and set it aside. It MAY be hanging from the brush holder in one of the shell halves. Unscrew both brush holders and remove them from the shell. Set them aside and reassemble the motor back into the shell. If the brushes are really short, like if they're nearly cube-shaped, then it's time to replace them. If not, try them again.
Insert one brush into each of the holes the brush holder screws came out of, and put the brush holder screws back in. Be careful not to cross-thread them. Try the tool.
If it still won't run, it's possible that an armature winding has given up the ghost and it's time to replace the tool...
Jul 11, 2014 | Dremel Multi Max Kit
No power to bite
Needs new brushes. http://www.metabo.com/Spare-parts-lists-handheld.16913.0.html
When the brushes wear down they are held back by there power wires.There should be a set of small holes in the brush holders.Push new brushes to the bottom and put a wire through the small holes to hold brushes in place during reassembly.Pull out the wires and the new brushes will seat. Brushes don't cost all that much.
May 07, 2011 | Metabo GE700 Grinder
How to assemble an electeic motor/ getting the armature past the brushes
The brushes are spring loaded (as you know), but if you look carefully, often there are small holes that a toothpick will fit into, in the track for the brush. Push each brush back far enough to put the toothpick into the hole, usually there is another hole on the other side, put the pick into that to hold the brush back. Repeat with the other brush, then install the armature. Once it is in place, remove both toothpicks.
Sep 05, 2010 | Chevrolet Corvette Cars & Trucks
Burshes will not spin, filter is clean
Drive belt missing or not properly installed on motor or brush/beater? Perhaps foreign matter caught in ends of beater brush that are holding the brush tightly in place. Clean the debris away and hit with a little WD40, but not much. Make sure it turns freely by hand prior to putting it back into place. If the belt is loose, make sure it is replaced with the proper belt and installed correctly.
Aug 28, 2010 | Hoover Vacuums
Fuse keeps melting
yes this can be repaired and no you wouldn't have to have an external fuse. What you need to do is first find someone that is good with a soldering iron. Next open the amplifier and look at the area where the fuse holder is located. You want to make sure that the area is clean and that the board is not damaged. To make sure that the area is clean well take some regular rubbing alcohol, 70% or higher,and a small paint brush put the brush in the alcohol and clean the area that was causing the problem regardless if there is any debris or not. This not only cleans the area but also prepares it for the solder job that is to come. Next take your soldering iron out apply solder wick to the board and remove all the old solder on the board. Make sure that you do not lift the pads that the connections are soldered to. after you have removed all the old solder from both the board and the fuse holder place the fuse holder into the slots where it belongs and apply some flux and fresh solder to the area. this will take no time to cool. be careful not to burn the board. After that has all been done put the amplifier back together and test it out. You should not have any problems after that.
Jun 03, 2010 | Nitro BMW-486 Car Audio Amplifier
Mower is oozing oil from bottom of fill tube which has come loose.How do i get it situated back tightly where it belongs? Craftsman Eager1 6.75
Check to see if a small bolt is missing. thats usualy all there is holding them in place. I had that problem before.
Apr 21, 2010 | Garden
HP Photosmart C5280 Printer Logo
211 people viewed this question
Seeker5211
Seeker5211
