Question about Air Hogs Toys
Air hog 0126 helicoper won't fly and fully charged. What could be wrong?
5 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: air hog hawk eye keeps
Hello Steve, remote controlled toys such as yours usually suffer from radio interference in environments with heavy duty radio equipments or in intense weather conditions. When the environment suffers from either of the two above mentioned factors usually when you are using your equipment there is a likelihood that the unit will cut out transmission mid way.
The controller sensors could be affected when the weather becomes too hot or too cold and therefore cut out transmission or receiving on the air hog hawk eye. Mostly it is not a problem just environmental factors. Try using it in a more friendly environment and get back to me.
Hope this solution has been helpful?
Merry Xmas to you
Posted on Dec 24, 2010
  • 17 Answers
SOURCE: fully charged but wont fly
There seems to be a lot of people having the same problems with this product with no idea of how to fix it so my advice would be to go to:
www.airhogs.com/#/need_help/hawk_eye
There the company that makes the product offers troubleshooting and if it fails they offer a phone number so that you can send it away to be repaired. Either try that or take it back to the shop where you got it from and get you money back.
Hope this helps
Posted on Jan 09, 2011
  • 10 Answers
SOURCE: We have a Air Hogs Hawk Eye that will fully charge
Simple, remember its controlled by infrared red signels from your tx to the rx most likely you have floresant lites? or live near some source of ir signals... plus dont forget that the big ball of fire we see in the sky emittes alll times of ir and other signals. maybe you have large windows facing the sun? either way test it like this, go in to a dark room, try to test the heli by carefully doing a control flight in the dark / dimmly lite room..
Posted on May 11, 2011
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
Airhog flights
Either you are klutz or it's probably defective if it is simply loosing power. A loose wire would be more erratic but check for other loose items. Clearly you have a failed connection somewhere.
Jan 01, 2014 | Air Hogs Toys
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Aug 09, 2011 | Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
We have a Air Hogs Hawk Eye that will fully charge but will not fly or respond to the remote control. Thanks for your help.
We had a simular problem - my son's unit was also stuck in picture taken mode - After contacting Spin Master (1-800-622-8339) it would appear that this is a known issue and they will replace the defective unit for free with proof of purchase.
You could also try to fully drain the unit (by leaving it on) and then re-charging it - apparently this has worked for some people.
Jan 24, 2011 | Air Hogs Reflex Micro Helicopter
My Web RC - Heli I. IR - Web Wolf isn't starting up even after I charge it. The instructions are very vague. What am I doing wrong
Hi! My sister's son had the exact same problem and after a quick look over the instruction manual I was able to get it to work. I have tried all the different Airhogs and this webrc is truly a superior flying toy. You can actually control it and make it go wherever you want to after you learn how to use the trim knob. Here are my suggestions to fixing the charging issue:
- Make sure the helicopter is OFF, - the batteries are fully charged on the controller/charger - and that the charging cable is plugged in correctly. You will know when you plugged it in correctly because the little light on the controller will change from red to green or vice-versa (cant remember) - the light on the controller/charger will change colors again when the helicopter is fully charged. - I am also an electrical engineer so I recommend you wait 10-15 minutes after turning it off and the same after charging it for optimal battery performance and life.
Hope this helps.
Have a safe flight!
Dec 25, 2010 | RC Toys
I have a brand new air hog jet set and I have charged it 5 times and only flew it 5 times. Now it only runs for about 15 seconds then dies. It shows to be fully charged, but it still only runs about 15 sec...
does the Air Hog Jet set for beginners AH-56 white have weights on the wings and on left center? their appears to be intents where possible weights would go but their not there, is this why it won't fly since purchase, could this plane have a deffect?
Dec 08, 2009 | Air Hogs Toys
Toys Logo
288 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
