Question about Yaesu POWEREX MH-C500Y Charger for FRS radios (VXF-10)
VX-1 Service Manual
Hello Mr./Mrs./Miss I have a Yaesu VX-1 with a freq offsett 10kh , Meaning
the rx and tx freq. is 10khz higher then shown in the display.
I have been told it is a setting in the service menu.
Can you tell me how and what settings in the menu to change?
I would also like a Service Manual for Yaesu VX-1
Aleksander Jensen (LA6MOA)
  • Anonymous Mar 14, 2014
    How do you master reset a Yaesu VX-3R?
  • Anonymous Mar 28, 2014
    VX-2
    New Friend:
  • 109 Answers
This address should help you out http://www.ham.dmz.ro/yaesu/vx-1r-ext-mic-diagrams.php
as for the service manual you will have to order that from yaesu or see if the local Ham radio sevice shop has an extra one they will sell.
Posted on Aug 21, 2008
I need help programming my baofeng 997s
To programme a repeater. VFO mode & curson on top line of display. Enter freq eg 147.250. Go menu button change settings like offset, tone. In menu delete channel required eg 000. In menu below that, choose mem channel now 000 & it saves receive freq.
Exit. press *SCN button so R appears on display. Save as 000 again but this time it stores TX freq. In other words, you save RX first, then exit.Add * so R appears in display second time round and save again TX freq. Go to channel mode and see it is in 000.
I might do a video to help people. Its the same process with UV5r and other Baofeng. Simplex you just save in one operation because TX is RX.
Aug 08, 2014 | Radio Communications
Yaesu ft-950
There are numerous possibilities. You really need to go through the steps in the manual very carefully. Some of the possible issues:
1. Cable wired incorrectly - tx/rx switched, etc
2. Communication rate set wrong on computer (or different from radio).
3. CAT not enabled on radio
4. Wrong version of CAT software.
Oct 03, 2013 | Radio Communications
MY YAESU 411E GOT OUT OF BAND WHAT SHALL I DO ?
Go online (possibly www.mods.dk) and get a user manual, Do a "factory reset"...
Sep 18, 2012 | Yaesu Radio Communications
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
How to save a favorite frequency on my Yaesu VX-1?
Thank you FixYa team support, I already find the solution.
B'rgads
Andy
Sep 17, 2009 | Yaesu POWEREX MH-C500Y Charger for FRS...
How to tx and rx between t5920 and yaesu vx6r
The T5920 is user programmable. It appears your VX6R does not have a CODE turned on, if you can receive transmissions from the T5920, but not talke back. The T5920 has both a CODE and a Qt filter. The Qt filter must be set to zero to communicate with other brands of radios. And to turn off your CODE, you will need to set it to zero also. Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
Jun 25, 2009 | Motorola T5920 (7 Channels) 2-Way Radio
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Yaesu FT-26 I got a Yaesu FT-26 that is used. The Problem by it is that its frequence between 140.000 and 148.000, i cant get lower or higher than, I cant even send or recieve anything!!! even when i press...
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Feb 23, 2009 | Vertex FNB-27SM,...
Yaesu POWEREX MH-C500Y Charger for FRS radios (VXF-10) Logo
2,721 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
