Question about Toshiba Satellite A75-S2112 Notebook
Dvd/cd not recognized by the computer - Toshiba Satellite A75-S2112 Notebook
  • 2,229 Answers
Assuming that it was working and now has stopped, you can try to run the utility called CDGone.
To find it, Google CDGone.
If this doesn't work, then most likely the drive has gone bad and must be replaced.
var fctb_tool=null; function FCTB_Init_d27594de151445438570d3de7b24bce4(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_b49e7f31f5434b8e8b4a151c25aecfdf(t) { fctb_tool=t; start(fctb_tool); }
Posted on Dec 29, 2010
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Wont recognize burned disk
Is the burned disk recognized in some other computer?
Is any "official" (purchased music CD, or purchased DVD video, or purchased Microsoft software) disk recognized when inserted into the device?
If you burn a disk on your computer, can your computer then read that burned disk?
May 29, 2010 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Why does my lenovo insist on my having a cd rom when i have a dvd writer installed? how do I fix it so that computer recoognizes it?
I have the same situation. My computer has a
DVD-RW/CD-RW installed yet when it is empty, the computer simply recognizes it as a CD drive. However, it will automatically recognize any DVD I place in the drive. Even a blank DVD-R. So it's not really a problem for me.
Also, if you type in DEVICE MANAGER in your windows search area, it will show you all your computer's hardware and peripherals. I have Windows Vista 64 bit and in device manager it does recognize it as an ATAPI DVD under "DVD/CD-ROM DRIVES".
I haven't seen a DVD burner yet that won't play or write cd's; maybe this is standard.
I wouldn't worry about it as long as it performs the functions (play/burn DVD's?)
Mar 14, 2010 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
Computer will not recognize external cd rom drive
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Mar 11, 2010 | Toshiba (PA3438U-1CD2) CD-RW/DVD-ROM...
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
Jan 26, 2010 | Computers & Internet
Music cd's are not recognized by my computers D: drive
Are you sure that you have a cd drive? It could be that it is only a dvd drive. It could also be that the cd has a scratch or is unreadable.
Apr 01, 2009 | Dell Inspiron 2200 Notebook
DVD doesn't open
This problem may be a bad cd/dvd drive. When the computer boots up, go into the BIOS setup. Check to see if the computer recognizes the drive, and make sure it is not disabled. Next, check in the "device manager" to see if there are any yellow question marks or red X's. This might indicate a driver problem, or a misconfigured drive. If these steps fail to resolve your problem, replacing the drive would be your next step. This is a fairly easy task, and worth the time to research the steps for your particular model.
Nov 15, 2008 | Gateway MT3705 Notebook
Sony CRX320EE combo drive not reading data disks
Reinstall nero and search google for removing nero scout
Robert
please rate the solution.
Sep 02, 2008 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
Toshiba Satellite A75-S2112 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
