Question about IBM ThinkPad A22m 2628 Notebook
I HAVE A IBM THINKPAD A22M LAPTOP WHEN IT BOOTS IT HAS A ERROR CODE OF 0271 CHECK DATE AND TIME SETTINGS AND BLANK SCREEN APPEARS AND A LOCK ICON APPEARS.... IT PROMPTS FOR A PASSWORD I DONT KNOW THE PASSWORD... THE F1 OR F12 IS NOT ACCEPTABLE TO THE COMPUTER PLS. HELP ME TO SOLVE THIS ERROR IN OUR LAPTOP SO IT CAN BE USABLE AGAIN SIR...........
  • 536 Answers
You will most likely have to remove the backup battery temporarily to allow the CMOS to clear the password lock.
The instructions for removing the CMOS battery are located here.
Be sure to disconnect the power cord and remove the standard battery when performing this work.
Be very careful to follow the directions exactly as shown.
You may have to leave the CMOS battery removed for a number of hours in order to clear the CMOS password.
Posted on Dec 29, 2010
After i remove litheum battery and restart. error 0271 - check time and date setting is what i saw n it lock again. what is wrong?
It appears the Thinkpad has a password lock on the BIOS.
This password cannot be removed by removing the BIOS battery.
For details on how to remove thisPassword click on this link -
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Mar 10, 2012 | Lenovo ThinkPad R51e Notebook
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
GOOD MORNING SIR / MAAAM.. MY IBM THINKPAD R50E HAS AN ERROR ON THE SCREEN ..."ERROR 0271 CHECK DATE AND TIME SETTINGS'.. HOW DO I CLEAR THE CMOS FOR THIS ERROR? HOW DO FIND THE PASSWORD PADS ON THE...
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS Battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new battery you can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the battery out or replacing it will get past your lock icon asking for the password. If not then you may have to find out the manufacturer of your computer's motherboard to see if there is a common password to get past the lockout. Since it's a laptop then it should be easier to find this code based on the manufacturer.
These links may help you with that:
How do I Reset an IBM ThinkPad BIOS Password?
CMOS Password locked on IBM Thinkpad
Nov 09, 2010 | IBM ThinkPad R50e Notebook
I CANNOT BOOT MY IBM THINKPAD 2367..HELP
Both errors are related to the backup battery which is located under the main battery. It is probably dead. You can get one on eBay for $3.29 w/free shipping or pay a shop $20 to put one in. If you do it yourself be very gentle plugging it into the tricky little slot - it is possible to break the connector loose from the motherboard but it is an easy repair if you have patience and dexterity. As for the password, try just hitting enter. It is the supervisor password to change the BIOS settings and was probably never set.
Hope this helps.
Jon
Apr 12, 2009 | IBM ThinkPad T30 (236781U08) PC Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
Ibm thinkpad locked code
I have notebook ThinkPad 2652, as including him it gives me that message.
"ERROR:
0271: Check date and time settins"
how то unlock it?
Any one cann help me?
Oct 04, 2008 | IBM ThinkPad A31 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Jul 17, 2008 | IBM ThinkPad T21 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
Boot problem
there is a security chip located on board the you may have tampered with or not i have seen cases where just simply putting a jump drive in the usb causes this error the chip sold on ebay for $14.99 if you need help open up the lappy please dont hesitate post i will help.
Apr 06, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad A22m 2628 Notebook Logo
341 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
