Question about Numark TT1650 Turntable
Hello i have a pair of tt1650 and both of the lose their speed! when i play the records both of them are slowing or going faster and i cant keep the bpm!! please help if you can
3 Suggested Answers
SOURCE: turntable motor keeps slowing down
Have you tried oiling the motor?
Posted on Nov 27, 2012
I found this which implies that the chip is faulty: http://petervis.com/record_players_and_turntables/Numark_TT1650_Slows_Down_Fault/Numark_TT1650_Slows_Down_Fault.html
Posted on Jan 02, 2015
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Sound does not match image and the sound is muffled
Perhaps, your Internet speed is too slow -- your computer "plays" the video FASTER than it can download it.
Or, your computer is too slow to be able to go into "full-screen" mode and keep updating the whole screen.
Jan 19, 2014 | YouTube Videos
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My asus netbook plays slow jerky videos when I watch them directly from the net. Anyone have a solution? Is this problem unique to asus or all netbooks? Thanks.
Hello
OK, you need to have a look at the buffer speed of the videos you are watching directly of the web.
It is actually all about the speed of the internet connection. A faster connection allows for the video to buffer faster than it actually takes to watch it, understand?
Thus, if you have a slow internet connection, the real time of the video will be faster than the video can be bufferred, so there will be pauses whle watching.
Thus, best advice without spending money, is to keep your flash player updated and let the videos buffer for a minute or 2 and then click play.
Kind regrds
Andrea
Dec 13, 2009 | Computers & Internet
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Numark TT1650 Turntable Logo
37 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
