Question about Husqvarna Husky 165
My Husqvarna 142 chain saw, new out of the box, starts and runs well enough but left to idle it continually stalls. Any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
The carb needs to be adjusted. Look for 2 adjustments label High(H) and Low(L). Low is the one that you want. Start you chainsaw and let it warm up and turn the L adjustment a until you are able to let it idle on its own. Hope this helps.
Posted on May 05, 2009
Husqvarna classica 105 - won't sew - thread wads up in bobbin area
this is a problem from the needle thread tension not tight enough
tighten the thread tension right up
Aug 08, 2016 | Husqvarna Sewing Machines
Trying to find an owners instruction manual for Husqvarna E. series 450 , 16 in gas chain saw.
Umm. Husqvarna makes both sewing machines and chain saws (good ones). But this needs to be posted in a category other than sewing machines. I would suggest "Home & Garden/Patio & Garden" as the most likely one I could find for you. Good luck.
Jan 26, 2011 | Husqvarna Sewing Machines
Hi,, my husque 141 dont seam to reach top end speed? it was ok till I cleans air filter
I am afraid you have confused sewing machines with chain saws!
One stitches fabric and the other makes a lot of noise and heaps of saw dust and wood chips.
Search the topics where the big boys play!
Mar 10, 2010 | Husqvarna Designer I
Chain saw probles
chain oil tank is pressurised...release pressure before storing...but it will still drip some
Mar 09, 2010 | Husqvarna Designer I
Husqvarna street (cut off saw) stalls when you tilt it forward. otherwise starts easy runs well
This is under the sewing machine category. You might want to resubmit under correct category if this is still an issue.
Dec 07, 2009 | Husqvarna Husky 165
Looking for spare parts for husqvarna electric chain saw. .Casing needing to be replaced.
Submitted to sewing machine category. Resubmit if still an issue.
Oct 02, 2009 | Husqvarna Designer I
Husky 55 chainsaw
All chainsaws are air cooled. The problem is the cylinder head often sits underneath the gas tank. People fill their tanks with a mixture of gasoline and oil and often spill it or overfill the tank causing that oily mixture to coat the cylinder often. Then all the saw dust and dirt sticks to the oil and pretty soon the cooling fins on the cylinder head and all the parts surrounding it are coated with an oily dirty grime that keeps air from circulating around the cylinder head letting it cool normally. I'm not that familiar with a Husky but you need to be careful about other parts in the area, but you need to clean off the cylinder head so that it can get some cooling and quit heating up the gas in your tank. Usually there is a vent in the gas cap also and if it's plugged it will cause the gas tank to pressure up and force more gas than is necessary into the carburetor. Either clean the vent or buy a new gas cap.
Apr 23, 2009 | Husqvarna Viking 1
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Is there a bar oil adjustment on my 36 cc husqvarna chain saw. Where might is be? Cheers paul
If there is one it'll be underneath the saw just behind the clutch cover/side plate. Though some of the smaller cc / hobby saws don't have an oil adjustment screw. happy hunting
Jun 29, 2008 | Husqvarna Husky 165
Sewing Machines Logo
560 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
