Question about Stanley 31200 TimerMax Indoor Weekly Digital Timer White
I want to program the timer to go on randomly. How do I do it?
Pressing the "TIME" and "PROG" buttons
simultaneously will activate security mode.
Security mode is vacation mode which operates timer randomly.
This information is taken from \'similar\' Westinghouse 28442 manual
http://waterheatertimer.org/pdf/28442_TimerManualEn&Fr.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Add a comment if manual above also works for the Stanley 31200.
Your feedback will help fixya community.
Posted on Dec 29, 2010
Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Dec 06, 2012 | Woods Hardware & Accessories
Have model TE02DHB/TE22DHB. Setting random mode but I do not see any "RND" on screen after following directions for random mode.
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
Timer has to be programmed first with on and off times.
Manual says press FUNCTION and RND digits 'flash' on display
Then press set button
Then RND will appear on display.
Timer then uses your programmed on-off times, and randomly varies programmed on-off times in range from 2 to 30 minutes.
So if regular program says ON at 7, then random will vary ON time from 6:30 to 7:30, assuming timer functions as shown in manual and timer is not defective.
If above information does not work, then use circuit analyzer and check polarity of outlet.
http://waterheatertimer.org/How-to-set-timers.html#polarity
Jul 18, 2011 | Hardware & Accessories
HOW DO I PROGRAM THIS TIMER
Open following link to identify GE timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
GE 50462 is vacation timer with preset program tabs, and cannot be programed to turn on-off at selected times
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 27, 2011 | GE 50462 7Day Random Vacation Timer
How do I get the RANDOM off and back to auto-on
You posted under a timer sold by several different Brands:
Open link below to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To enter random mode, press DAY and HOURS buttons at same time.
To reverse selection, press same buttons again.
Many programmable timers will not work in random unless timer programs are separated 1/2 hour apart.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 18, 2011 | Woods Industries 59377 Indoor Digital...
How to program residential timer mod no 49750/tm261a
49750 sounds like a Woods timer number, but I can't identify for sure
Woods makes timers for many other brands that are sold under different numbers
Amazon shows First Alert tm261 random vacation timer
http://www.amazon.com/First-Alert-Tm261-7-Day-Vacation/dp/B000P6W4OE
If this is not your timer, then add a comment.
First Alert tm261 random vacation timer is similar to GE 15151 shown on following page.
GE 15151 has a manual
First Alert appears just below GE 15151
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
A vacation timer cannot be programmed.
Look closely at outer edge of dial and see that dial has small plastic protrusions that stick out.
These protrusions are trippers that cause timer to turn lights on-off at random times so home looks occupied when on vacation.
Dec 26, 2010 | Woods Hardware & Accessories
For GE- 15117, Mode acts as a controller called "an On or Off override..." "or sets events to Automatic or random" Random = a +/- program shift (that's understandable). You'd think...
I cannot make precise sense of your question.
However I agree, the manual for GE 17117 is not clear.
1) A number of folks are writing in about this particular timer, with same MODE problem as you.
Some folks, the timer skips over auto.
Some folks the timer just doesn't come on.
Facts are facts, some timers are busted on arrival.
But let's look at the problem from three different directions and see if it helps:
2) Steps from manual:
When you finish programming, press clock button to return to current time.
Next set MODE.
Press MODE button and timer enters override ON-OFF. Override reverses whatever program is operating at that moment.
Press MODE button again and timer enters RDM random mode, and lights turn on-off randomly.
Press MODE button again and timer enters AUTO >>> auto is correct setting that lets programs run.
Here's the trick: after setting MODE to auto, press clock button again and current time displays.
If timer will not perform these steps, then timer is suspect
If timer performs these steps, but programs won't work, the timer is suspect or programming is suspect.
3) Check programming for conflicts and overlaps that cause timer not to function 'as expected.'
Some timers skip over conflicting programs, some timers simply stay on, others stay off.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
Example of conflict is event1 ON at 7am TU > but event1 OFF at 11pm All-days. Both event1 ON and OFF events must have consistent days >>> so change TU to All-days.
Another example is event1 ON 7am OFF 11pm TU >> but event2 says opposite, or has overlapping times.
I suggest folks make a schedule of programs before starting.
To review and change programs, start with current time showing in display: Press PROG button and scroll through event1 ON, event1 OFF, event2 ON, event2 OFF, etc.
Write down the events and make a chart.
Look for overlaps, and check for days of operation, and make sure each event ON has corresponding event OFF
4) If events are correct, and timer MODE button functions, but timer still doesn't work, the final suspect before calling the timer busted, is circuit problem. Use circuit analyzer on receptacle. Or plug timer into receptacle on different breaker and see if problem persists.
Dec 11, 2010 | GE Hardware & Accessories
Have the timer set on Auto but lights are not on during the ON period. Also do I need to set times for all 7 periods?
No, you do not need to set all 7 timer events.
When event1 ON and event1 OFF are set, press CLOCK button to exit programming and save programs. Or press PROGRAM button and move to event2 ON and event2 OFF. Exit programming any time by pressing clock button.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
That being said, if events conflict with each other, timer will not operate.
For example event1 ON FR at 7pm and event1 OFF all-days at 11pm.
The days have to match for on-off times.
Another example event1 ON FR at 7pm and event1 OFF FR 11pm, but event2 ON all days 8pm event2 OFF all days 10pm. This overlap will cause timer to skip programs.
If timer is being used in random mode, timer programs cannot be closer than 1/2 hour apart.
When programming is done, press clock button to display current time.
Timer should be ready to go.
Manual is fuzzy at this point, and does not specifically say, but it appears that you only press MODE button when you want to set another mode beside auto.
I e-mailed Intermatic last week about this unclear spot because several folks are writing in about this timer not going into correct MODE after programs are set.
MODE must be set to automatic
Press MODE button once for manual override function
Press MODE again and RDM displays for random >> this is for lights turning on randomly when on vacation.
Press MODE button third time, and AUTO shows on display >> you want timer in AUTO for timer programs to operate.
Here's the trick ... after setting MODE to auto, press clock button to display current time
If timer will not enter AUTO, then timer is defective.
If Intermatic sends response that is pertinent to your question, I will post again on this thread.
Add a comment any time, and I will respond.
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have set program 1 on and off times and program 2 on and off times but do not know what mode to choose to get it to work!!
People are writing in with problems about HB88RC.
Problems seem to revolve around MODE button and setting automatic for timer to operate programming.
One guy said his timer skipped over automatic.
Another fellow today reported that timer programs would not work.
So maybe your timer has similar problem.
I'm going to e-mail Intermatic with recent information.
I need clarification on your exact question.
Intermatic generally e-mails back and is concerned with their products and customers.
That being said, let's look at your timer problem.
When you finish programming 1 and 2, press Clock button to exit programming and current time shows on display.
At this point, timer should function.
According to manual:
If you press MODE button once, timer will enter override, and lights will turn on.
Press MODE button again, RDM shows on screen and timer enters random mode and lights turn on-off randomly so it looks like folks are home.
Press MODE again and timer returns to Automatic and programs 1 and 2 should run.
Add a comment and let me know what is happening so I can report to Intermatic.
I will post results on this thread.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
I also am having trouble with this timer. I've got the program set for when I want it to go on but can't figure out how to put in the time I want it to stop. I don't understand where the countdown timer...
ETW350 is programmable timer that offers 3 different timer
functions: Program, countdown and random.
Timer has 20 different settings.
UPM site is not available recently, but UPM timers are still being sold.
Operation manual is not very clear how to program ON and OFF times.
http://waterheatertimer.org/pdf/UPM-etw350.pdf
That being said, usually with programmable timers, you program ON time. And then program OFF time.
I do not own this timer so I can't test ETW350 like I've tested other timers.
I think the way this timer works, is program1 is ON.
And program2 is OFF.
Again, manual is not CLEAR about ON and OFF times.
Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
Here's how to set program1.
Press arrow buttons until 1 shows in display. This is program1.
Press Set button.
Select day for program1 ON using arrow keys
Press Set button.
Select hour for program1 ON using arrow keys.
Press Set button.
Select minute for program1 ON using arrow keys.
Press Set button.
Use arrow keys until 2 appears on display. This is program2.
I believe program2 is for OFF times.
Set program2 using same steps above.
Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
Make a schedule of program times before starting to avoid conflicts.
Try steps above and test fire that timer, and then add a comment.
Nov 24, 2010 | UPM Programmable Wall Switch Timer
How to reset the programming on timex lamp timer TX12694TA
For some Timex timers, press PROG and MODE at same time to reset timer.
Open following link for random Timex manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Jul 14, 2010 | Hardware & Accessories
Stanley 31200 TimerMax Indoor Weekly Digital Timer White Logo
386 people viewed this question
Top Stanley Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Sean Fick
Sean Fick
Level 1 Expert
Are you a Stanley Hardware and Accessory Expert? Answer questions, earn points and help others
