Question about Timex 50-Lap Ironman Triathlon 59221 Wrist Watch
Changed battery on ironman, watch got wet, now doesn't work
I've worn my Ironman in the pool many times before. Just had the battery changed for the first time, went in the pool, and now the watch does not work at all. Assuming the battery changing broke the water resistant seal??? any suggestions??
Thanks.
  • 109 Answers
The bad thing about most Timex watches is that once you open them it is very hard to resael them again. The thing is that , the screws are metal, and your trying to tighten them into a plastic back. If you try to tighten them too much you mess up the tap. When the back is first put into the watch there is a very small hole. When they screw them in it's like a wood screw it taps itself in to the back. Once that has been done once it is very hard to keep the same tighteness it started with. Your best bet is to get a watch with a metal screw-on back with a metal casing too. That way you can tourque really hard and make sure the back is tight. If you decide to have the battery changed, make sure they silicon the seal.That's about as much protection agaist water you have with that watch.
Posted on Jul 07, 2008
Changing battery on ironman 30 women's watch
You can go to Walmart and buy a battery and they will change it for you,but these watches,won't work right afterwards,they are throw aways.Check this link out. https://groups.google.com/forum/#!topic/rec.sport.triathlon/MDzuLEyzMKM
May 03, 2017 | Ironman Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
Timex ironman 100 lap battery replacement
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area, the tools you"d need, time and the risk in ruinning your watch doesn"t out way the small cost of the shop changing the battery.
May 20, 2010 | Timex Sports Ironman Triathlon 100-Lap...
The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
Why is my ironman draining my battery?
Over time the circuitry in a watch can become worn and corroded.  This corrosion is usually barely noticeable.  More often, you won't be able to see much damage at all.  Nonetheless, the circuit is worn and is giving too much resistance to the battery.  This is cause the battery to pump too much voltage into the circuit just to run the watch.  This is draining your watch very quickly.  This is more common as the watch gets older.
Jan 10, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Timex 50-Lap Ironman Triathlon 59221 Wrist Watch Logo
369 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
