Question about Lands Phones
Uniden Axis has gone blank. No display, but the screen is lit. This has happened in the past. A day or two later the information has been restored at those times. Not this time. The handset beeps constantly. Red light indicates battery problem. Unplugging it is the only way of stopping it. Does the handset battery affect the memory or display? Is there a way of extracting the data?
    Genius:
  • 1,417 Answers
What this problem indicate from the phone respond to the command mean that the screen of the phone has been forth i.e gone bad from the flex connected to the panel of the of the phone.
What you need to do to to fix up the problem is to get a a better flex from any of the phone store around you that deal with phone an accessory ,then unscrew the phone then carefully remove the case to avoid more damage on it then remove the flex some time in brawn or while color the replace the new one you purchase from the store .
Note: make sure that the newly flex is compatible/ and tested with the old flex before living the store ,however,remove the phone battery if possible then replace it and try to change it again make sure that the bettery is well position before changing then you will be able to extract the data in the phone memory.
In addition to the solution of the problem , phone battery does not affect the memory of the phone it can only affect the display of the phone if the battery has lost it power because it will not be able to power the panel of the phone.
Good luck and thanks for using fixya.
Posted on Dec 29, 2010
My new uniden phone,xdect6145bt+h ,the display screen went blank what should i do?
You phone is completely discharged, it should be charged while charging some kind of icon should appear on screen indicating charging is in progress. If nothing appears then your phone's charging system has gone damaged and to be taken to technician.
May 15, 2014 | Lands Phones
Good Morning. One of the handsets in my Uniden DSS7815+1 Cordless phone system fails to show any information at all, even though the handset can make and receive calls normally. The screen just sho
The circuitry has gone out in the phone, nothing more you can do, but replace it, might be able to find one on EBay, unless you can live with it that way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Uniden Lands Phones
2008 Triumph Street triple instrument display not working
Hi, Chuck if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Gauge cluster died bike wont start HELP
Instrument Cluster not displaying tach neutral light speedo engine temp
Triumph Speed Triple Service Manual
https://www.triumphestore.com/
Triumph Speed Triple User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 01, 2017 | 2008 Triumph Street triple
My uniden axis phone when dead ysterday. There is no information on the display just the light is on
My Uniden digital powerMax 5.8Ghz hand phone went dead and does not want to take a charge, although the base unit red charger light is on.
Mar 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Printer screen is lit but blank
Change the display flat cable
Berurier gave the solution
http://sites.google.com/site/bricolagesetc/home/my-experience-guide-repairing-pixma
You'll spare time and money.
Jul 12, 2009 | Canon PIXMA MP520 InkJet Printer
Does not get past the Verizon screen when turning the phone on.
I hate to be the bearer of bad news but the only thing i would say try is taking the battery out for about 30 seconds. putting it back in and trying again. if it does not turn on then i'm afraid the phone will not come back. It's a somewhat rare problem but does happen.
Unfortunately all information is gone unless you had downloaded backup assistant.
Apr 13, 2009 | Samsung SCH-a870 Cellular Phone
Screen goes blank at start up
Its failing to go through the full boot process. Try pressing F8 on boot until the boot option screen comes up and then select safe mode. Follow this though until you are given the option of using system restore instead of safe mode. take that option by clicking on the NO button. Restore the machine to a date some time a few days previous to the fault developing.
If that fails then put in any OS disc and boot from it. select R at the first options screen, follow it through and then select the C drive option. Just hit enter when asked for admin password.
now type chkdsk /r (copy and paste this to be sure). let it run and then reboot and see what happens
Dec 15, 2008 | Dell Latitude D600 Notebook
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
LCD Screen is blank
Had the same thing:
Step 1 - remove the battery for about 60 minutes. There seems to be a little energy store in the unit and just taking out the battery, counting to 10, and reinstalling it does not work.
Step 2- Do a software update upgrade from the Logitech site. The new firmware level seems to have fixed the base problem.
If you just take the battery out and put it in, it does not work.
If you take the battery out and just hook it up to do a software upgrade, it does not work becuase the remote gets power from the USB commenction so it remains "hung"
The most disturbing thing about the whole event for me was the number of people that had the problem occur about 12 months and 1 day after purchase....ie when it was out of warranty!!!
Oct 20, 2007 | Logitech Harmony 890 LCD Remote Control
Cd players locks up when power switched on
arg... email numark they will give you a uk brach to email - there is a reset facilty that may help you (sorry cant rememeber the buttons it was yonks ago) while it sorted mine 'scratch' is now permanently lit only... they suggested a servide to clear that one prob but got used to cueing the record on that deck in scratch mood which is an art in itself lol
Sep 18, 2006 | Nu Mark AXIS 9
Lands Phones Logo
140 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
