Question about ASUS A7S-A1 (90NMVA4A32212CQL300T) PC Notebook
I have an ASUS A7S. It is dead. Nothing happens when it is plugged in/turned on. The power supply works and it is getting power to the board. The main fues may be blown. Can you tell me where the fuse is? I have it apart but have not found the fuse.
  • mag70x7 Dec 29, 2010
    I asked where it was located. You did not answer my question. Where is it located? This is an Asus A7S laptop. Please answer my question.
  • ASUS Master
  • 12,061 Answers
Hi, well sorry to hear you are having problems. There are no fuses "per sa" there are however fusible links, or resistors, however these are unlikely to be the culprit. but worth a check, to do this one must obtain a service manual for your exact make and model.
One has to work through a procedure to isolate exactly what is wrong. First we must establish if the PSU is working 100% OK.. To do this you need a Volt meter. Check the actual output against what is written on the actual adapter itself. It will indicate exactly how much voltage there should be, it should be exact. If not there is a problem. If the PSU is OK, then good proceed on.
After checking the PSU, remove the battery, now connect the Known Good PSU. Check to see if there are any LED's on at all.? If yes, then simply remove items, such as RAM, HDD, DVD, one at a time, disconnecting and reconnecting the PSU in between..
If after you remove something and the machine then responds, more, then this is your most likely problem, and will need to be replaced.
If however you get no improvement at all then most likely you have a Motherboard fault. If so and you still wish to DIY repair, then you will have to somehow obtain a service manual, to enable you to service your laptop.
As with anything electronic that needs to be serviced, one always starts at the Power Supply, in the PC, this needs to be checked to male sure all the voltages are correct going out to all the parts of the circuits, and the faulty one(s), examined as to why this is so. usually though, motherboard faults are dealt with by replacement.
Posted on Dec 30, 2010
  • 1,557 Answers
The fuse your looking for is a pico this is what they look like I have an ASUS A7S.  It is dead.  Nothing happens - sonicboomele_5.jpg
Posted on Dec 29, 2010
My motherboard is dead replaced power supply still nothing
you may got a power spike if so board bad look at the board the caps are they round or flat if rounded on top bad board
Jan 13, 2013 | HEWLETT-PACKARD Hewlett Packard GV34469001...
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
Hello my name is Amy & I have a 50 inch toshiba dlp (56hm66). I have no lights on or power. It's completely dead!!! I read the manual & followed everything about the lamp, how to restart, made...
Tv have no power at all?U already check the source?Yes,most likely the tv DM power supply board is dead or could be anythings on the highvoltage deflection circuitries on the tv.Check the DM power supply board like for dying or dead capacitors and circuit fuse breaker.Have no skills to do this call and get an estamate by tv Tech. to get it fix.
Jan 13, 2011 | Toshiba 50HM66 52" Television
My hp monitor is totally black it was working last night. i tried to unplug and replug it in and it came on for a few seconds then went black again
A lot of time people have the impression that the monitor is not working when in fact the computer is not booting its lighting up but nothing else so its stays on a black screen.
One way to know is by opening your speakers or plugging head phones, if you hear windows open or any windows sound the problem is the screen.
You can also unplug the screen from the pc and turn the screen on most of the time the screen while show a disconnected warning on the screen if that comes up the computer is defective.
Oct 29, 2010 | HP Computers & Internet
I turned off the tv using the on/off button and when i went to turn it on today it failed to turn on. Nothing at all happens, the outlet is working fine. I purchased the tv at Wall-mart, mason City, Iowa
Power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 21, 2010 | iLO 3200 32 in. LCD Television
I cannot get the tv to power on from either the remote or the control panel. The manual says that if that is the case then you are to press the system reset button on the control panel and a green light...
Ur tv the power supply board it dead.That the board where the power a/c cord plug into it.Replaced the power supply board,ur tv will have power back and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacenent.
Jun 14, 2010 | Mitsubishi LT-52149 52 in. LCD HDTV
When I use the remote to turn the television on, nothing happens.
This problems happen to all LCD and Plasma tvs.In to 1 or 2 maybe 3 to 4 years old in used.The power supply board have these componnents parts call the capacitors,it will started to bulges up on it top,or puff up on it top.These capacitors are leaking gases and it dead.The tv will not power up and the LED power lite indicator start continuous flashing LED light.U know basic electronic's and soldering?Take the tv aparts where the power cord plug into it that ur power supply board.Searches all around the power supply board and it supporting boards,replaced all those dead gas leakage capacitors.Ur tv will power up normal again and work.Or Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 24, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Two months old dead no power
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Oct 08, 2009 | ASUS Computers & Internet
ASUS A7S-A1 (90NMVA4A32212CQL300T) PC Notebook Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
