Question about Samsung DV218AEW Electric Dryer
Our Samsung dryer has a burning smell, and it appears to have burnt lint in the air intake at the back of dryer. Can I open the intake to get it out?
  • 139 Answers
SOURCE: dryer burning smell
Is the fan running....with strong airflow out of the vent pipe? Is the smell coming from the vent pipe? If the vent pipe goes outdoors...is the smell coming from the control panel at the top??
ODOR FROM VENT:
If the fan is not running, or the air is somehow blocked, then the odor is probably caused by excessive heat around the heating element. A seriously overheating element should eventually cause a thermal overload protector to "trip" and shut off the power.
If the airflow is strong, the air intake may have drawn in paper, dust, lint, or something that is near or stuck on the heating element.
ODOR FROM CONTROL PANEL:
A relay, temperature control, timer module, or other part may be burning out. The defective part could possibly be found by "sniffing" the parts in the control panel to find the source of the smell...with the power unplugged!!...otherwise, this may require testing by someone familiar with appliance repairs.
Posted on Jan 22, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
lenwest
  • 150 Answers
SOURCE: Dryer won't start and smells like something is burning
Sounds like you have lost your cycle timer or control panel.I would replace it or have it replaced.
let me know
Posted on Feb 17, 2009
ned_san_jose
  • 234 Answers
SOURCE: Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Posted on Jul 07, 2009
  • 102 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
My maytag neptune dryer makes a grinding sound,and
I have no clue about the grinding but most likely the smell is burning lint. I'd recommend vacuuming out as much lint as you can. The better choice is open case and vacuum all of the lint.
Sep 12, 2014 | Dryers
Burning smell in dryer
Have you checked the motor? Plenty of lint and dust gets indie it. If you can remove if and use compressed air to blow it out. Also don't overlook the fact all the spade connectors will also collect lots of lint and dust which is quite flammable. Also check the tensioner and guide wheel they get pretty dirty and when they heat up the lint can start buring.
Aug 11, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
The clothes are coming out of the dryer smelling burnt.
you probably have lint build up on the heating element. the lint will burn when the heater is on, and transfer the burning smell to your clothes inside. Probably time to take it apart and vacuum everything out .
Jul 20, 2011 | Dryers
All the clothes in my dryer dry at a normal time, but the smell burnt! After a dry cycle, the inside of the dryer smells like something is melting, but everything seems to be working correctly. We have had...
Remove the vent duct at the back and clean out all of the lint. Next, find the air inlet to the heater elements and make sure there is no lint accumulated there. Inspect the back of the drum (inside) for any plastic debris (something left in a pocket?) that might have melted and stuck on there. Last resort: remove the dryer cabinet and drum, and inspect the heater and its wiring. If the insulation on the wires appears burned or is broken off, cut off the damaged part of the wiring and replace its terminals, then polish the heater terminals before reattaching the wires (a tarnished connection will cause the wire to overheat). Clean out the heater if necessary, but be careful not to stress the heater element. Used heater wire is brittle and cracks or breaks easily.
Jul 04, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Burning smell when dryer is on
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 11, 2009 | Amana NDE2330AY Electric Dryer
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
DLG5988W Gas dryer
you might want to check you venting, if tis not clear, your lint might be building up inside machine and burning off as you use your unit.
Mar 01, 2008 | LG DLG5932W Gas Dryer
Samsung DV218AEW Electric Dryer Logo
2,424 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
