Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Charging problem my ipod is not charging
    Master:
  • 382 Answers
Please sure about your connections and also try connect your Ipod in a different usb drive..I had the same problem which got fixed when i changed my usb port used for connection..Thank you!!..
Posted on Jul 10, 2008
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
on Aug 09, 2011 | Apple iPod touch
What could be the problem if my iPod Classic won't charge?
Be sure to connect the charging/sync cable directly to the computer, not a USB hub. Most hubs are don't provide enough power to the usb ports to charge the ipod. If you need a method of charging the ipod while away from the computer connect your sync cable to a device like these: Even the USB port on Apple keyboards is not able to charge the Ipod.
If you're using the computer to charge the Ipod, be sure it stays on, when computers go into sleep or standby modes they stop charging your ipod. You may want to use one of the options below to charge your Ipod when the computer is off or in a different location than the Ipod.
For use inside: Best prices for a Belkin brand power adapter for Ipod click here
For use in the car: Best prices for a Belkin brand car power adapter for Ipod click here
May 10, 2011 | Apple iPod classic MP3 Player
Ipod does not charge - ipod and speakers are new
Hello :
You have problem with the charging jack . Take it to the service .
good luck .
please rate !
Nov 01, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Directions say it charges and syncs. When I
Look at:
http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models.
Oct 09, 2009 | Altec Lansing inMotion® iM500 Docking...
Ipod player wont charge ipod
I probably have the same type charger / player that I also purchased from Wal Mart. If it plays your ipod it should also charge it. Make sure the lock button on the ipod is unlocked and it's turned off. If that does not work keep it unlocked and leave it on. On systems like we have that are not iHomes they sometimes have trouble figuring out what brand they need to charge.
Aug 15, 2009 | Apple iPod nano MP3 Player
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
What type of IPod is this? Also what type of charger are you using? If the ipod does not have a charge at all you will need to plug it into a wall charger for it to get a "Base charge" (this usually takes 5-10 minutes) as if the ipod is totally dead then there is not enough of a charge for the ipod to let your computer know it is there to start being charged. After it has the base charge you can use the usb connection to finish the charge or leave it plugged into the wall charger to finish getting the charge.
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
